88 Grand Wagoneer hard to start/stalls in heat - JeepForum.com
post #1 of 8 Old 06-15-2010, 05:30 PM Thread Starter
gareth
1988 FSJ Wagoneer
I just bought an 88 Grand Wagoneer for my wife as she's always loved them. We drove it overnight 300 miles back from Miami with no trouble.
The next day we drove it in the heat - after about an hour of driving in 90 degree Florida heat it stalled while driving at about 30mph. Engine would not turn over when the key was turned.
After towing it back to our mechanic friend's house, it started up as if nothing had happened.
His first suspect was the battery, so we had the battery and alternator tested at Autozone and both passed.
We replaced:
  • Fuel pump
  • Ignition module
  • Battery top ends
  • Fuel filter
Our mechanic drove it around in the heat for an hour or so the next day, and it had no trouble.
We took it home the next afternoon, filled the gas tank and 100ft down the road it stalled again. After 45 minutes of sitting and priming the carb with gas it started up and we were able to drive it back home.
Starting up this morning took a few tries for it to turn over. This afternoon (after sitting in the heat while my wife was at work) it took 20 minutes to get it to start.
It also idles rough, if that helps to diagnose the problem. Not sure if these old Jeeps just idle rough anyway, though.
Any suggestions as to how to make it easier to start, or what I should try next to diagnose the problem?
gareth is offline
post #2 of 8 Old 06-15-2010, 07:04 PM
CutterN55
looked at the terminals on the starter solonoid? maybe they are loose. bad engine grounds? try swapping in a coil? coil sitting on valve cover and getting too hot?
also take a look at the engine harness on the pass side from the coil to the relay and to the starter. pull off all the plastic wrap and look real hard for burns, chaffing, or rubbing.
going by what you said not being able to turn it over, sounds electrical, but you are also showing signs of vapor locking.
I'd check position of the filter and I use a spacer under the carb to keep block heat from traveling up and boiling the fuel in the bowl. When you are having a real hard time starting it, pull off the top of the carb and look in the bowl and see if there is any fuel in there.
Semper Fi!
86 CJ7 258/Np435/D300/Waggy D44's
CutterN55 is offline
post #3 of 8 Old 06-18-2010, 04:52 PM
polardoggie
1979 J-Series Truck
both problems i had.i am in south fla also ...ford starter solinoid on passenger fender,would heat up and not start....also sounds like vapor lock ...i installed a electiric fuel pump and fuel pressure regulator(be sure get a metel one-ie Holley...cheap plastic ones from autozone leaked in less than a week)and mount fuel pump down near fuel tank..that should solve your problems
polardoggie is offline
post #4 of 8 Old 06-21-2010, 05:38 AM
megajeep
1989 FSJ Wagoneer
Starting cold and stalling after it gets hot is also a symptom of the ignition resistor wire going bad. As it gets worse it will become harder and harder to start in cooler temperatures until it wont start at all.
Of course this has nothing to do with the starter turning over. Perhaps you have more than one problem.
megajeep is offline
post #5 of 8 Old 06-28-2010, 11:22 PM
JJMalibu
Grand Wagoneer 89 too hot to start (again)
I have a 1989 Grand Wagoneer and have the same issue.
I drove to Palm Springs this week and the engine wouldn't start again after driving for 15-30 minutes (drive... park and then I cannot start the engine). The problem is that I cannot even pump fuel in the carburetor. I replaced the gas pump (it was 10 years old anyway) but I am not sure this is the real solution.
I read the previous comments... What would the coil have to do with this issue... Is there a way to avoid vapor locking? If not, what to do to start the engine if it happens. Thanks for your help
JJMalibu is offline
post #6 of 8 Old 06-29-2010, 10:18 AM
polardoggie
1979 J-Series Truck
coils break down over the years ,much like all electronic parts,from heat..try a electric fuel pump,for vapor lock...before i did this i would have to pull fuel line off filter to allow pressure to equalize...mind you i have a 60 gallon tank and a large spin on type fuel filter...im in south fla now...truck came from cali..dont know if they had problems out there or not..
post #7 of 8 Old 06-29-2010, 04:24 PM
PYROBOB
Power valve or the vac/temp thingy these jeeps are known for.
PYROBOB is offline
post #8 of 8 Old 07-01-2010, 01:05 AM
JJMalibu
Thanks for your input.
I will replace the coil and get an electric pump as a back-up.
It was 105 degrees in the desert... and it sounds like vapor lock is very common there with older cars.
Another question... What are would be your choice for new tires (I am not doing off road) with white walls?
Thanks in advance!
JJ
JJMalibu is offline
Grand Wagoneer Won't Start JustinPolley Full Size Jeep Forum 5 06-09-2010 11:36 PM
Heat riser pipe for AMC 360 (Grand Wagoneer) - where to get? lopoetve Full Size Jeep Forum 2 10-04-2009 10:24 PM
Grand Wagoneer was garaged, now can't get it to start! fingertrap Full Size Jeep Forum 3 08-12-2009 04:56 AM
1990 Grand Wagoneer hard to start when hot Poe Full Size Jeep Forum 5 08-04-2006 11:28 AM
93 grand wagoneer 5.2L No Start lmsc66 Full Size Jeep Forum 1 08-25-2005 09:28 AM
