88 Grand Wagoneer exaust leak - JeepForum.com
post #1 of 3 Old 03-18-2011, 05:00 PM Thread Starter
Behrwagon
Hi,
Just bought and 88 Grand Wagoneer 360 V8. I am having trouble figuring out my exhaust leak on the driver side. Replaced the individual gasket's but still leaking. Manifold does not appear to be cracked. Air tubes are no longer in place and holes welded up and not leaking from there. The leak seems to be from the front under side inbetween cylinder 1 and 3. Is this a common problem on these? Thanks
Behrwagon is offline
post #2 of 3 Old 03-22-2011, 10:06 PM
Eric1080
1978 J-Series Truck
bad gasket maybe?
Eric1080 is offline
post #3 of 3 Old 04-08-2011, 04:07 PM
STEELHORSE6
the cast manifolds are junk they are prone to cracking and warping, its probably the mating surface isnt flat due to being warped, one fix is take it off and have it milled flat, or find a JY replacement, possibly without the AIR fittings.
STEELHORSE6 is offline
66 Wagoneer or 89 Grand Wagoneer jlsfitness Full Size Jeep Forum 12 01-24-2012 09:40 AM
Grand Wagoneer Main Seal leak. DookJones Full Size Jeep Forum 3 10-22-2009 11:44 AM
4wd system died in my 89 grand wagoneer--vacuum leak? Lizsgrdwagoneer Full Size Jeep Forum 2 08-06-2009 02:13 PM
wagoneer/grand wagoneer differences? JeepnBlake Full Size Jeep Forum 1 08-26-2008 11:33 PM
Grand wagoneer grand cherokee engine- KWAG Full Size Jeep Forum 0 04-29-2005 08:55 AM
