87 grand wagoneer new fluids - JeepForum.com
post #1 of 10 Old 06-27-2013, 12:08 PM Thread Starter
Nelson88
1987 FSJ Wagoneer
Hey, I just bought an 87 grand wagoneer this week, and one of the first things I want to do is change the fluids. I've read good things about using Shell Rotella 15W-40 with a Wix filter for the engine. I'm looking to also change the transmission fluid (and filter), transfer case and differentials and was wondering what to use.. It has a 360 with the 727 tranny, I'm not sure about the transfer case and I'm pretty sure it's Dana 44's front an rear. Thanks for any help.
Nelson88 is offline
post #2 of 10 Old 06-27-2013, 05:32 PM
olliehopnoodle
1982 FSJ Cherokee
Congradulations on the purchase!
It is a dana 44 front and rear. There is a 'slim' chance you have a traction loc rear end. It will want special fluid (although the clutches are probably warn out either way). You can check the tag and/or often times there was a warning sticker in the glove box.
Do you have full time or part time 4wd? I think what you use for it will matter (you either have an np208 or np229)
I don't have an opinion on transmission fluid. I always get confused because the original stuff isn't available. I have a note written down in my booklet, I will take a look when I get home.
I run valvoline vr racing oil only because it has a higher zddp content which is good for the flat tappet cams we run.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #3 of 10 Old 06-28-2013, 12:44 PM
super98lsc
x2... also the rear diff should have the axle ratio tag and another tag with the fluid spec for the traction-loc if equipped. My 90 w HD Tow package has the 3:31 trac-loc. I ran Royal Purple Synthetic in it.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #4 of 10 Old 06-29-2013, 03:57 PM Thread Starter
Nelson88
1987 FSJ Wagoneer
It has part time 4WD, with the selector for 2WD or 4WD and the hi an low lever on the drivers floorboard, which I thinks cool lol. Thanks for the help, I can't wait to start tinkering on it.
Nelson88 is offline
post #5 of 10 Old 07-03-2013, 06:00 AM
StayClassy
Any other Grand Waggy owner been using Shell Rotella in their 360? Curious if the heavier viscosity has made a noticeable difference.
StayClassy is offline
post #6 of 10 Old 07-03-2013, 09:17 PM
super98lsc
Valvoline racing, only parts store oil with enough zinc the deisel oils do not have enough in them any more. Brad Penn racing, or Joe Gibbs oils.are the other two I use in my flat tappet engines.
post #7 of 10 Old 07-03-2013, 09:54 PM
lucdog
lucdog's Avatar
1980 CJ5
This^^*
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #8 of 10 Old 07-09-2013, 10:00 AM Thread Starter
Nelson88
1987 FSJ Wagoneer
I don't want to open a can of worms saying this but from what I've researched most people say to use Shell Rotella 15W-40, but there's also people that say to use Valvoline racing (no specific weight) because of the higher zinc content. I bought 5 quarts of the shell and my buddy who has a diesel got pretty concerned when I showed him. I'mwondering which one to use before I give my jeep a drink.
Nelson88 is offline
post #9 of 10 Old 07-10-2013, 08:32 AM
super98lsc
Don't run the diesel stuff it does not have enough zinc. Any cam manufacturer or builder will vouch for me on this one. I use the Valvoline and spike it with additive.
post #10 of 10 Old 07-10-2013, 06:09 PM
StayClassy
After reading more into this ZDDP issue, it looks like there are a handful of motor oil manufactures that make oil specifically for flat tappet cams, as Super98 stated above. And there are a ton of threads all over the Internet in various automotive forums discussing this issue. There's a really great thread on a Corvette forum that's worth searching out. I'm too lazy to attach the link.
I just filled my 360 with Valvoline VR1 10W-30 this past weekend. Thanks for the recommendation Super98.
