87 grand wagoneer help - JeepForum.com
post #1 of 5 Old 04-14-2013, 10:24 AM Thread Starter
ayycharlay92
I have a 1987 grand wagoneer, I just redid the trans in it, but now I'm leaking oil, think its coming from my valve cover, so I was wondering exactly what I need to do to change the valve cover gaskets
ayycharlay92 is offline
post #2 of 5 Old 04-14-2013, 11:15 AM
RockRollin
1990 FSJ Wagoneer
Biggest part is to get other things cleared out of the way, label and relocate. Are the bolts tight, they can often come loose over time. I was told years ago"when tightening valve covers use a nut driver so you can't over tighten" always thought that was safe.
Check what you have first
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #3 of 5 Old 04-14-2013, 04:26 PM
revelc
1985 FSJ Wagoneer
I use a 7/16 with a long wobble extension and a 1/4 drive ratchet to snug them up. I did pull mine off when they were leaking, wiped them down and cleaned the valve cover and head too. Then I put a dab of RTV where each nipple protrudes out of the cover and they didn't leak again.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #4 of 5 Old 04-15-2013, 12:47 PM Thread Starter
ayycharlay92
I got new gaskets, they were only $13 so it's worth the cash to change them
post #5 of 5 Old 04-15-2013, 12:52 PM
revelc
1985 FSJ Wagoneer
It never hurts to play it safe. Some gaskets are fine to reuse. Some aren't. But peace of mind is always great.
revelc is offline
