#1 | |
86 GW vacuum line help
can anyone show me a good site or pictures or anything to replace the vacuum lines on my 86 grand wagoneer, now im not looking for diagrams but pictures to help me out better
#2 |
I know Tom has the diagrams. Maybe pics too?
http://oljeep.com |
#3 |
i was there, those factory diagrams are sooo confusing to me lol, was just hoping there was a better guide with actual pictures =/
#4 |
Heero, I am making an updated diagram of original. I am also going to be taking photgraphs later today to point out all of the details so I can rebuild the vacuum system easier once I have it torn apart. It is rather confusing to me as well!
2004 Jeep Wrangler Unlimited, Automatic RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers - Power Door Locks with Keyless Entry Build Project Thread Rocker Guard Comparison Chart - Final Differential Gear Ratios - Oxygen Sensor FAQ |
#5 |
if u could share that'd be awesome as whomeever had my jeep before not only where some lines missing, some chewed but some where plugged into wrong places so i cant even go off of where they are placed now
#6 |
I'm glad I know enough about these systems to reroute them to my liking. Back in the day, they jury-rigged the emissions in these things just to pass. Taking more modern designs into account, I up the spark (something Jeep should have done when it became available) with a Dodge electronic ignition coil or the Ford TFI one (basically the same as the TFI upgrade)
Then I dump the AIR system and go with a non-aerobic high flow catalytic converter (stock one needs the air. NA cat doesn't and will in fact self destruct if you leave the AIR pump working) I plug off the lines on the exhaust and hook up the EGR to work like the '74 diagram shows and keep the fuel vapor canister. With everything simplified, I can pass the emission test at levels MUCH lower than required. Last trip I took my '84 J10 through (6 cyl) it passed at low enough numbers to beat '94 regs (they accidentally input the wrong year at the testing station) |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
