'86 Cherokee Chief - JeepForum.com
post #1 of 10 Old 01-27-2006, 04:03 PM Thread Starter
Cherokeechief86
'86 Cherokee Chief
Not sure if right forum. 1986 Jeep Cherokee Chief (think 86 was last year they were made). Drove it all of 4 miles before the engine started knocking and locked up. Has a 2.8L Carb V6, need to know what other year/size engines would fit. Cannot find a 2.8L v6 anywhere near this year/type locally.
Cherokeechief86 is offline
post #2 of 10 Old 01-27-2006, 05:07 PM
jode
Nope - it aint...we dont know nutting bout them mini-jeeps here...just the full sized ones
Hung like Einstein and smart as a horse...
90 YJ, 2.5L, 5-speed
jode is offline
post #3 of 10 Old 01-27-2006, 06:05 PM Thread Starter
Cherokeechief86
not little
No, this isnt a little Jeep. It resembles a mid-size suv in size and shape.
post #4 of 10 Old 01-28-2006, 12:51 AM
1986Comanche
1986 MJ Comanche
The Jeep Cherokee (XJ) was made from 1984 to 2001. 1986 was the last year for the 2.8L V6, but was not the last year for the Jeep Cherokee (XJ).
1986 Jeep Comanche 4x2, 2.5L I-4 TBI, 4 Speed
Blue Jeep Club Member #123
Easy to be a truck. Hard to be a Jeep.
1986Comanche is offline
post #5 of 10 Old 01-28-2006, 03:41 AM
Woody
Retired back to Bowties
Woody's Avatar
1985
If your Jeep even closely resembles this you have an XJ not an FSJ.
The guys in the Cherokee forum can help you with it.
PM me if this is what you've got and I'll move it to the Cherokee forum for you.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #6 of 10 Old 12-25-2010, 12:12 AM
davsfsj3xjs
1987 FSJ Wagoneer
If it is a '86 xj Cherokee with a 2.8 v6, you can drop a 3.4 Camero short block for more power, or you can look for another 2.8 from a chevy or gmc s-10 truck or blazer- jimmy. The 3.4 will fit with your intake, exaust, flywheel, damper, valve covers, and oil pan if I remember correctly. Good luck to you.
davsfsj3xjs is offline
post #7 of 10 Old 12-27-2010, 02:07 PM
sang_route
1989 MJ Comanche
Or hunt down a vortec 4.3. Little more common in the 4 door blazzers and should fit the same trany.
Cafinaholics Anomous me and anyone that has way too much coffee in a day!
And yes I can't spell... Live!
88 and 95 XJ, 1973 J4000
sang_route is offline
post #8 of 10 Old 12-27-2010, 02:44 PM
Eric1080
1978 J-Series Truck
or sell it and get an 83 or older cherokee and join the club..... or keep it and buy and fsj....
Eric1080 is offline
post #9 of 10 Old 12-28-2010, 12:53 AM
davsfsj3xjs
1987 FSJ Wagoneer
The problem with the 4.3 Vortec (great engine), is the wiring harness. Yes the engine will bolt up, but the 3.4 block with your intake, and accessories, will add more power and less headache. Unless you have a solution to the vortec harness problem, this is a good way to go. Let me know if there is a harness solution. I would rather have the 4.3 power plant, obviously. Cheers, Dave
post #10 of 10 Old 12-28-2010, 03:17 AM
carnuck
1984 J-Series Truck
4.3L has a different bell pattern than the 60 degree motors. It's the same as SBC (small block chev)
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
'77 jeep cherokee chief sandstorm Full Size Jeep Forum 13 03-23-2008 02:42 PM
79 Cherokee Chief..need new seat covers and headliner UTIJeeper Full Size Jeep Forum 1 09-07-2007 09:42 AM
Cherokee Chief t-case 76CherokeeChief Full Size Jeep Forum 4 04-29-2005 02:56 PM
Cherokee Chief XJ99 Full Size Jeep Forum 4 05-01-2004 08:51 PM
78 or 87 cherokee chief dzp Full Size Jeep Forum 0 02-24-2003 07:09 PM
