85 Grand Wagoneer no power - JeepForum.com
post #1 of 25 Old 03-06-2013, 08:21 AM Thread Starter
whitey659826
1985 FSJ Wagoneer
I have a 1985 Grand Wagoneer I put in a new battery, starter solenoid and still no power at all when I turn the key. Any ideas? Everything looks right to me, is there a single fuse that is used for that system. If I turn the ignition to the start position I get the seatbelt light to come on, on the dash. Any help is greatly appreciated!
whitey659826 is offline
post #2 of 25 Old 03-06-2013, 09:02 AM
timgr
1975 CJ6
Neutral safety switch?
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
post #3 of 25 Old 03-06-2013, 09:04 AM Thread Starter
whitey659826
1985 FSJ Wagoneer
The transmission is out at the moment, its a recently acquired project. If that switch wasn't in the circuit, would kill everything?
post #4 of 25 Old 03-06-2013, 09:13 AM
Gonovr
Gonovr's Avatar
1988 FSJ Wagoneer
Is the engine grounded and are the grounds good?
Im not good but im slow.
1988 Grand Wagoneer 5.9l bone stock.
*SOLD*2001 Tj Sahara
*SOLD*1997 XJ Sport
Gonovr is offline
post #5 of 25 Old 03-06-2013, 09:49 AM
pleontks
1976 J-Series Truck
If the plug for it is there, but unplugged, it will not start. Your starter solenoid should have a 5th connector on the bottom or back. Ground this connector, and you should start.
Beauty is in the eye of the jeepowner.
pleontks is offline
post #6 of 25 Old 03-06-2013, 11:11 AM
RockRollin
1990 FSJ Wagoneer
If you have no power to anything, start checking the fusable links coming from the solenoid
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #7 of 25 Old 03-06-2013, 11:28 AM Thread Starter
whitey659826
1985 FSJ Wagoneer
Thanks for the replies, I will check the fuse able link tonight.
post #8 of 25 Old 03-06-2013, 11:30 AM Thread Starter
whitey659826
1985 FSJ Wagoneer
The negative terminal hooks directly to the engine I'm pretty sure.
post #9 of 25 Old 03-06-2013, 12:29 PM
muddy93
1987 FSJ Wagoneer
Check that negative cable really well. When my 87 developed a "no power" situation like this, it ended up being a bad negative cable, even though the cable looked good. To test, simply use some jumper cables as a temporary ground(from battery negative to engine),and see if there is any change. If you get power with the temp ground, you need a new cable.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #10 of 25 Old 03-06-2013, 02:24 PM Thread Starter
whitey659826
1985 FSJ Wagoneer
I will have to go over everything again. The power worked for a second then went dark. So something had to of fried I just need to look through the haystack
post #11 of 25 Old 03-06-2013, 04:40 PM
RockRollin
1990 FSJ Wagoneer
If it blanked out completly when you engaged the starter (lights, seat belt light, ect), chances are its the ground
"I like fun" Edd
post #12 of 25 Old 03-06-2013, 06:32 PM Thread Starter
whitey659826
1985 FSJ Wagoneer
The negative lead is attached above the ac compressor is the sufficient or should it be to the block?
post #13 of 25 Old 03-06-2013, 06:47 PM
Gonovr
Gonovr's Avatar
1988 FSJ Wagoneer
Now is there a ground going from the engine to the body or from the battery to the body. The engine is pretty much isolated by rubber. You need to make sure the body has a good ground also.
You could always move your engine ground to the head or block. It should be ok on the compressor if the compressor bracket makes a good connection to the block.
*SOLD*1997 XJ Sport
Gonovr is offline
post #14 of 25 Old 03-06-2013, 08:19 PM Thread Starter
whitey659826
1985 FSJ Wagoneer
At the moment there is only one wire coming to the negative terminal of the battery, coming from the top of the ac compressor. I am going to add one going to the body as well. I have come to the realization that this truck needs some serious electrical work! Hack upon hacks upon hacks....That what happens when you get a truck thats been hanging around since 85.
post #15 of 25 Old 03-06-2013, 09:15 PM
olliehopnoodle
1982 FSJ Cherokee
Hey!
Okay, a little more info on what is happening will help.
With the key out:
Do the head lights work?
Interior lights?
As a 'general' rule the lights are isolated from the starting system.
When you say the 'transmission is out' do you mean 'out' like it isn't working or 'out' like it is not installed? Without the transmission in the safety switch won't be hooked up and I am pretty sure the engine won't crank at all.
Do you have a multimeter? If not, get one! Super cheap and a big help. I can help talk ya through how to use it.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
