85 front dana 44 - JeepForum.com
post #1 of 3 Old 03-21-2002, 06:53 AM Thread Starter
rollinashortysahara
85 front dana 44
any one know how to change the hubs to some that will be able to disconnect (warn, etc...)?
rollinashortysahara is offline
post #2 of 3 Old 03-25-2002, 07:00 PM
99BoggerTJ
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by rollinashortysahara:
<strong>any one know how to change the hubs to some that will be able to disconnect (warn, etc...)?</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">Well im not positive if its the identical axle that i took apart last week, but this might help.
Ok well old grands have a metal cap which yu just pry off. Then you shoudl see the stub shaft and a c clip on the shaft or around the outside in the groove of the hub casing. Take those out, and the metal hub piece is spring loaded and should pop out. Now all you have to do is order warn its eitehr 17 or 19 spline hubs, slide in the first part, install the axle shaft c-clip, and the outer ring, and then place the hub on and install the 6 bolts.
Hope this helps, need any more info email me and ill do my best.
Goodluck
99TJ, 5 spd, 7 inch RockKrawler Severe Duty Long Arm Tri-Link, Atlas II 4.3, D44s front and rear with 4.56's, ARB's, custom cut 38.5x14.5 Swamper SX's on 15x8 AR Bajas, custom cut 35x14.5 Boggers, 35x12.5 GoodYear MT/Rs on Ultra 50's, Warn 9500HSi, Tom Woods driveshafts, Kilby gas tank skid, Hanson rocker panels, EOR full roll cage, Borla exhaust, and much more.
99BoggerTJ is offline
post #3 of 3 Old 03-27-2002, 08:12 PM Thread Starter
rollinashortysahara
thanks a ton yeah it is the same and that sounds like a beast of a tj you have , i have a yj that i'm either gonna spingover with dana 44 front and rear (possibly a 9" in the rear) or will do a warn coil conversion a few years and a few thousand dollars and i'll be where i wanna thanks a ton
Front dana 44 off 81 wagoneer ?s JRW7072009 Full Size Jeep Forum 5 08-25-2009 12:38 PM
Front Grand Waggy Dana 44 breather hose foggybottombob Full Size Jeep Forum 6 08-06-2009 01:04 PM
82 grand wagoneer front dana 44 please help jeepwyj94 Full Size Jeep Forum 4 03-24-2009 11:49 AM
need a front dana 44 Commando360 Full Size Jeep Forum 0 06-06-2008 09:32 PM
How do you tell if the front end is a 30 or 44 dana bikeoregon@juno.com Full Size Jeep Forum 1 05-29-2001 01:31 PM
