84 Wagoneer - mysterious toggle switch - JeepForum.com
post #1 of 22 Old 03-20-2013, 05:44 PM Thread Starter
Quantumspores
Hi folks,
I just picked up an '84 Grand Wagoneer Limited and I'm trying to determine the function of an on/off toggle switch on the left of the steering column. See attached pic.
Thanks!
Quantumspores is offline
post #2 of 22 Old 03-20-2013, 06:35 PM
Dave145
1976 FSJ Cherokee
Looks like an aftermarket switch to me. Have you tried flipping.it on and seeing if anything lights up or happens?
Dave145 is offline
post #3 of 22 Old 03-20-2013, 07:08 PM Thread Starter
Quantumspores
Of course I tried flipping the switch :-).
But there is no easily observable function and I really don't want to go tracing wires!
post #4 of 22 Old 03-20-2013, 07:39 PM
pleontks
1976 J-Series Truck
does it still start when you flip it?
Beauty is in the eye of the jeepowner.
pleontks is offline
post #5 of 22 Old 03-20-2013, 09:20 PM
jeepdj5
1982 FSJ Cherokee
I have no clue how the quadra trac works on these but is it electric? Or maybe it's the rear defogger, or curse??? Does it look like it ever had aftermarket lights on it? Heater fan? Look around, turn the key on and look at the voltage of the battery (you can do it in the cab from the cig lighter plug) with a voltage meter, turn on the switch and see if it goes down like its actually running something, if it goes down its running something, if it satays where it is probably does not work or any thing
Sent from my fsj Cherokee chief using JeepForum
jeepdj5 is offline
post #6 of 22 Old 03-20-2013, 10:55 PM
88wood
Could it be a switch for an electric locker? Or it could be a switch to the wagoneers lights in the alternative universe that coexists next to our own. Joking
88wood is offline
post #7 of 22 Old 03-21-2013, 02:53 AM
RockRollin
1990 FSJ Wagoneer
Flux capasitor?
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #8 of 22 Old 03-21-2013, 06:13 AM
Dave145
1976 FSJ Cherokee
Could be a switch for fog lights that were once on the truck and are no longer there. Are there any holes where aftermarket lights could have gone?
Dave145 is offline
post #9 of 22 Old 03-21-2013, 07:27 AM
Little Green
1991 FSJ Wagoneer
Any rear lights. I hooked up a set of fog lights on my JK and had a toggle. Great for camping or backing up
91 Grand Wagoneer(Winter vehicle/project)
Prior 08 Wrangler JK Lifted-Miss her
Little Green is offline
post #10 of 22 Old 03-21-2013, 07:47 AM
jeepdj5
1982 FSJ Cherokee
Repeat
jeepdj5 is offline
post #11 of 22 Old 03-21-2013, 05:54 PM
timgr
1975 CJ6
The switch was definitely added by one of the POs.
Obvious - take the cover off the bottom of the steering column and see where the wires go.
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
post #12 of 22 Old 03-21-2013, 06:32 PM
luckywagoneer
1989 FSJ Wagoneer
Try hitting it when your driving its got to be a turbo switch or its a transformer. I got a switch like that it turns on my nightrider light so sweet.
luckywagoneer is offline
post #13 of 22 Old 03-21-2013, 09:40 PM
jeepdj5
1982 FSJ Cherokee
Repeat
See if the voltage drops when you turn on the switch
jeepdj5 is offline
post #14 of 22 Old 03-22-2013, 08:17 AM
kfcandtanq
1985 FSJ Wagoneer
That's your "ECONO" switch.
When you flip it on, you'll get the same fuel mileage as a Prius.
kfcandtanq is offline
post #15 of 22 Old 03-22-2013, 08:21 AM
jeepdj5
1982 FSJ Cherokee
Wow damn I wish there was one on my 82 chief!!
jeepdj5 is offline
