84 Wagoneer Fuel Gauge / sending unit - JeepForum.com
post #1 of 9 Old 03-22-2013, 01:05 PM Thread Starter
Quantumspores
Hi Folks,
So i've got a fuel gauge problem that is driving me slightly insane. I have a 1984 Grand Wagoneer limited where the fuel gauge is always showing empty. I replaced the sending unit but still the guage shows empty. The sending has two attachments, one for a red wire, the other a black wire. When I added a second ground wire from the black connector to the frame nothing changes. When I place that second ground wire from the red-wire connection point to the frame the gauge spikes to full and stays there. Thus it seems the gauge is functional.
Any suggestions?
Quantumspores is offline
post #2 of 9 Old 03-22-2013, 09:33 PM
1983Chief
It sounds like your signal wire is the problem. Try tracing it down and see if its broken or corroded anywhere. Or you could just run a new one...
1983Chief is offline
post #3 of 9 Old 03-22-2013, 10:41 PM
RockRollin
1990 FSJ Wagoneer
Is it wired backwards?
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #4 of 9 Old 03-23-2013, 08:20 AM
timgr
1975 CJ6
http://www.jeepforum.com/forum/f57/f...gauge-1495777/
Have you read the '84 TSM about fuel guage diagnosis? The TSM typically has a very helpful flow chart that tells you how to diagnose gauge problems.
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
post #5 of 9 Old 03-23-2013, 08:44 AM
RockRollin
1990 FSJ Wagoneer
I just went to link the same topic, check last post.
That is what I was referring to the reversal of the ohm resistance in the 85 to 86 model year to mark full.
"I like fun" Edd
post #6 of 9 Old 03-24-2013, 03:57 PM Thread Starter
Quantumspores
No, the polarity is not reversed, I checked.
I confirmed the ground is good by running a ground directly to the battery as a test, no change.
post #7 of 9 Old 03-24-2013, 05:29 PM
RockRollin
1990 FSJ Wagoneer
I was incorrect in saying polarity, it is an opposite signal from the 85to86 year model.
You can check the signal at the guage, or the sending unit as timgr suggested.
63-85. 73 empty, 10 full
"I like fun" Edd
post #8 of 9 Old 03-27-2013, 11:12 PM
GuyPatterson
test the continuity from the sending unit to the gauge; this should tell you whether you have a break in the wire. I used some spare wire to extend reach of my multimeter and tested the continuity. If a good signal is getting to the gauge, your gauge is likely busted.
GuyPatterson is offline
post #9 of 9 Old 03-16-2014, 09:09 PM
oldiron4me
Ok..try this and feel free to comment..help appreciated. I restored my 85 J20. Pulled tank and washed it out and cleaned Everything..painted Everything correctly. Ground is good and even added new extra ground to cleaned bare frame location. Wire to gauge is all new, ground wire new.
At half tank gauge reads full PLUS. All other gauges working correctly. Dash cluster grounded well with an additional ground wire added just to be sure. New gauge and sending unit from Team Grand Wagoneer, and all installed correctly, new tank vent and all vent lines and fuel lines new. Everything but tank and skid-plate/straps are new. I even cleaned and inspected the dash backing when it was out/apart and cleaned the 'racetrack' ground and all connections and harness. New fuses, New battery, new alternator, new engine harness..all running fine. When I first fired it up to run the cam break-in on new engine..it read half tank and as I started with a clean empty tank, I knew it was exactly a half tank I put in. Then it went to full+ and stayed there when key is on or truck running. ...Anyone ?
oldiron4me is offline
