84 wagoneer axle swap - JeepForum.com
post #1 of 3 Old 01-31-2007, 05:02 PM Thread Starter
jumpmonkey77
I have a 89 yj with a 350 and unfortunately d30 rear that is just waiting to explode. I just got a line on a 84 wagoneer that I could pick up for free (sort of, I'd have to get it from Va to CT). I believe it has d44s front and rear.
Has anyone done this kind of swap? Is it worth the hassle?
Thanks
JM
jumpmonkey77 is offline
post #2 of 3 Old 02-01-2007, 03:28 PM
BLS33
Chief of the brain police
BLS33's Avatar
Your rear axle is actually a dana 35c.
The dana 44 is a fairly common swap if you google it you should be able to find most of the info you need, if you plan on bigger tires and lockers it will be worth the hassle to go 44 or stronger.
BLS33 is offline
post #3 of 3 Old 02-02-2007, 08:20 AM
J4GRAND
An 84 Wagoneer if it is the full size Grand Wagoneer will have an AMC 20 axle in the rear. These were used from 80-mid 86. It is not the same 20 as in CJs, it has one-piece axles as is as strong as the 44.
Patrick V.
Valparaiso, IN
73 Jeep J4000 360 .040 over, Summit K8600 Cam, Edelbrock Manifold and 750CFM 4V TH400/1339 QT
78 Cherokee Chief- Hunting Property Rig
05 Grand Cherokee- 3.7 V6 5 speed auto
J4GRAND is offline
76 wagoneer rear axle rodimusprime Full Size Jeep Forum 5 07-02-2009 04:16 AM
wagoneer axle shaft problems jeepwyj94 Full Size Jeep Forum 3 04-02-2009 05:46 PM
75 Wagoneer Chevy Engine swap tilley52 Full Size Jeep Forum 7 06-16-2008 09:45 AM
Jeep Wagoneer axle question Bclevy Full Size Jeep Forum 2 12-04-2007 07:42 PM
72 Wagoneer rear axle removal tommy b Full Size Jeep Forum 8 12-01-2005 04:57 PM
