84 GW 360 exhaust question - JeepForum.com
post #1 of 4 Old 05-01-2007, 03:56 PM Thread Starter
kmjbpkohler
I'm wondering if anyone is familiar with this exhaust. Can u tell me if there are doughnut gaskets between the bottom of the header and the exhaust pipe. I can't find any, or they are fused to the header bottom so well that you can't see a seam there. Also, can anyone tell me what the heck that little flapper thing is on the bottom of the passenger (starboard) side header with the spring attached to it? Any information would be helpful.
Jeeps are alot like houseboats
kmjbpkohler is offline
post #2 of 4 Old 05-01-2007, 06:03 PM Thread Starter
kmjbpkohler
Ok, got the "flapper" off, do I need to leave it on or is it ok off? Nothing is attached to it as far as a sending unit or vacuum line. By the way, I now know this ia a "heat riser damper" aka flapper
post #3 of 4 Old 05-04-2007, 08:14 PM
jeepfan93
1991 FSJ Wagoneer
Unless yopu building a custom exhaust, the Y pipe will not bolt back up dsue to the extra distance from removing the flapper. And there should a dougnut on the port side manifold.
jeepfan93 is offline
post #4 of 4 Old 05-17-2007, 10:42 AM
carnuck
1984 J-Series Truck
If you don't have a functional heat riser, your motor will take longer to warm up and fuel economy will suffer. (it forces exhaust through the port in the intake to the other side and out that exhaust until the motor is warmed up) If you have a warm climate, it won't matter much.
carnuck is offline
401 Exhaust 1976Wagon Full Size Jeep Forum 8 01-23-2010 10:59 PM
Raw gas in the exhaust 1swtjeepski Full Size Jeep Forum 0 10-31-2009 03:30 PM
Exhaust LiftedWagoneer Full Size Jeep Forum 11 04-24-2009 10:51 PM
Exhaust location question bigdawgfan Full Size Jeep Forum 4 02-01-2009 06:45 AM
Exhaust 1989 Saleen Full Size Jeep Forum 2 05-29-2004 08:35 PM
