84 grand wagoner - JeepForum.com
post #1 of 24 Old 01-14-2014, 07:37 AM Thread Starter
Bignate57
1984 FSJ Wagoneer
84 grand wagoner
Just picked up a 84 gw no rust and drove it 2hr home. To begin with it ran like crap. A tank of good gas helped, I think the timing is off.
My question is there is a dinging when I turn on the headlights. Any thoughts would be welcome.
Bignate57 is offline
post #2 of 24 Old 01-14-2014, 07:41 AM
CrawlingForward
Dinging as in like...a door chime type deal? Or a sound coming from somewhere in the vehicle like the engine, etc.?
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #3 of 24 Old 01-14-2014, 11:46 AM
muddy93
1987 FSJ Wagoneer
My 87 has a "you left your ligts on!" chime that kind of "dings".
It's only supposed to "ding" if the lights are on and the ignition is off. I'd start by finding a wiring diagram specific to your year, determine if you in fact have the "lights on chime", and then check the related wiring.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #4 of 24 Old 01-14-2014, 12:00 PM
ChrisHager
Administrator
ChrisHager's Avatar
If I recall, my 79 makes a buzzing sound when the lights are on, key is off, and door is opened. Kind of like zzzzaaaaaaa. Maybe zzzzeeeeeeeeeeeeee. Could possibly be a key somewhere between the two as well. Zzzzaeaeaeeaeaeaeaeaeaeaeae. I'll check when I get home.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #5 of 24 Old 01-14-2014, 04:54 PM Thread Starter
Bignate57
1984 FSJ Wagoneer
Thanks for the input. The sound is like a door chime.
Tinkered with the timing today and it runs a lot better. Could not find the indicator for the timing, not familiar with these, kind of a ford guy
post #6 of 24 Old 01-14-2014, 06:15 PM
Spaceball
That's what my '78 does too, kinda sounds like a sick kitty meowing
Spaceball is offline
post #7 of 24 Old 01-14-2014, 07:15 PM
Renodemona
1976 FSJ Cherokee
I have a "fasten seat belts" buzzer. Definately a zzzzzzeeeeeeeeeee for about 5 seconds when you first turn the key past the accessory position. No lights chime.
Renodemona is offline
post #8 of 24 Old 01-14-2014, 09:19 PM
ChrisHager
Administrator
ChrisHager's Avatar
Hahahahaha I've gotten a kick out of these posts, mainly the way we are trying to spell sounds!
Look from either the passenger side behind the pulley brackets OR look from the front towards the passenger side through the spinning fan blade (if you don't have a fan shroud). Watch your fingers though!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #9 of 24 Old 01-15-2014, 03:38 PM Thread Starter
Bignate57
1984 FSJ Wagoneer
Ordering shop manuals today this dinging is driving me crazy. No radio to turn up!
post #10 of 24 Old 01-21-2014, 05:33 AM Thread Starter
Bignate57
1984 FSJ Wagoneer
How can I tell if the 4wd is engaging. When I turn the switch I hear the vacuum but nothing lights up and the high low leaver will not move. I would assume from other post that it's not engaging. Is the actuator on the transfer case?
post #11 of 24 Old 01-21-2014, 06:31 AM
BJ's Off-Road
1979 FSJ Cherokee
It could be the actuator on the xfer case or the switch on the dash. Double check all your vacuum lines, make sure they are hooked up and don't have holes or tears in them.
If all is good, you can pull off the actuator on the transfer case, hook up some vacuum line to the nipple and use a vacuum pump (or suck with your mouth) and see if it is moving. If it is moving, it is probably your dash switch.
www.bjsoffroad.com
BJ's Off-Road is offline
post #12 of 24 Old 01-21-2014, 08:37 AM
RockRollin
1990 FSJ Wagoneer
You should only hear the vacuum for 1-2 seconds. Much longer and its leak chasing time.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #13 of 24 Old 01-22-2014, 06:13 AM Thread Starter
Bignate57
1984 FSJ Wagoneer
Thanks, vacuum sound is for about 2 or 3 seconds. When it warms up I'll check it out.
post #14 of 24 Old 01-22-2014, 06:16 AM Thread Starter
Bignate57
1984 FSJ Wagoneer
Took a little road trip up to the cabin yesterday. Getting about 13.1 mpg. Still has all the vacuum hooked up.
post #15 of 24 Old 01-28-2014, 12:09 PM Thread Starter
Bignate57
1984 FSJ Wagoneer
Got my books in Saturday there the wrong books. Faxon is sending new ones. Put new tires on rides a lot better. My wife didn't like that the headliner was drooping so I had that fixed and she is complaining about..... Everything. I have jeep therapy two days a week now.
