84 Grand Wagoneer 4x4 not working - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > 84 Grand Wagoneer 4x4 not working
SYE Kits from CCOR! 706-207-4140Stainless Steel Door Hinge PinsPoly Door Hinge Bushings
Unread 10-21-2014, 01:26 PM   #1
ninaskillingme
1984 FSJ Wagoneer
First things first, I would like to appologize for my lack of knowledge. I am new to this forum so please be gentle.
I've had this Wagoneer for 3 years now, and have been working towards getting it fully roadworthy and dependable. Just had the top end of the engine rebuilt, and numerous other replacement parts. I have never owned or used a 4x4 before this one. I was told when I purchased it that the four wheel drive needed vacuum lines to work. The Vacuum lines for the transfer case are completely missing.
My question is, if I have no intent on using four wheel drive and there is no possibility of engaging it...should I be expecting any headaches in the future rendering my wagoneer inoperable?
If I do replace the Vacuum lines, and there is a problem....then what?
I love my jeep, but I'm running out of money and patience. Any advice would be greatly appreciated.
ninaskillingme is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 04:45 PM   #2
lindel
The basic result of the vacuum lines missing will be that you have a 2wd Jeep. If you ever decide to make 4wd functional, you'll have to make sure that the vacuum lines to the front axle and the transfer case are intact and in good shape. The 84 and 85 Wagoneers have a front axle with a vacuum disconnect. You won't be able to select 4wd if the front axle vacuum actuator isn't working.
Lindel
His: 1999 TJ Sport
Hers: 1987 Grand Wagoneer
lindel is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 06:16 PM   #3
ninaskillingme
1984 FSJ Wagoneer
Thanks Lindel, That is what I was thinking & hoping to hear!
Unread 10-21-2014, 06:38 PM   #4
lindel
You'll just need to make sure that there aren't any stray vacuum leaks due to open ports or lines. In fact, it would probably be a good idea to check all the vacuum lines on it to begin with.
Good luck with it, if you need more help, just ask.
Lindel
His: 1999 TJ Sport
Unread 10-21-2014, 07:37 PM   #5
CSP
Not all 84s and 85 have a vacuum disconnect front axle. It depends on what transfer case the particular Waggie has in it that determines what front axle it has.
Some '83s also have the vac disco front axle.
CSP is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 09:19 PM   #6
lindel
True, but the majority of the Wagoneers/Grand Wagoneers have got the NP229/NP228.
83 doesn't surprise me in the least, given AMC's habit of grabbing whatever happened to be on the shelf...I've seen 78s with the later door latches and 79s with the old latches. I had 2 79s, one with old and the other with the new.
Lindel
His: 1999 TJ Sport
Unread 10-21-2014, 10:42 PM   #7
NOPA318
That ain't no joke. Remember DonS Wag? It came from the factory with a bigger engine than a 401. I can't remember exactly what it was, but it was proof that AMC didn't have their poop in one sock.
To the OP, there ain't no shame in a 2wd G-wag. (watch!VVVV)
https://www.youtube.com/watch?v=mIWvlz9G_go
NOPA318 is offline   Reply With Quote Quick reply to this message
Unread 10-22-2014, 06:40 AM   #8
lindel
I remember Don's Waggie very well, saw it in person several times. It's living in Oklahoma with another mothership member.
Loved the stories about ghimni Jeep.
Lindel
His: 1999 TJ Sport
Unread 10-22-2014, 07:33 AM   #9
ninaskillingme
1984 FSJ Wagoneer
Thanks again guys, I am going to get up underneath and check it all out this weekend.
Thanks for the Video Nopa318.
Is there a model number on the transfer case that I should look for?
If so, where should I look?
She's not my Daily Driver. But I Drive her whenever possible. My main goal is to make sure it is mechanically safe, and dependable....I don't like surprises, and I've had more than a few of those with this one. I will let you guys know what I find and we'll go from there. Thanks again!
Unread 10-22-2014, 07:56 AM   #10
NOPA318
There should be a round tin tag on the center back of the t-case with the image of New Process's logo, a red gear on it. In the gear there will be stamped numbers, I believe the serial number is on top and the model number below it. Should be 229AM or the like.
Unread 10-22-2014, 09:45 AM   #11
ninaskillingme
1984 FSJ Wagoneer
Thank you Nopa318, That is very Helpful! I will check it out as soon as I can! Once I know the devil that I am dealing with, It will be easier to find the right exorcist.
