84 Grand Wagoneer 4X4 light switch? - JeepForum.com
post #1 of 4 Old 12-20-2003, 10:34 AM Thread Starter
raycr
I'm tring to get the 4X4 light to work and can't find the dang vacuum switch for it. anybody know where they put it?
Thanks ,
Raycr
raycr is offline
post #2 of 4 Old 12-29-2003, 07:48 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Assuming that you have a Qtrack, the switch is in the glovebox. These sometimes fall through,so if you don't see it,look behind the hole
jeepdaddy2000 is offline
post #3 of 4 Old 12-30-2003, 11:33 AM Thread Starter
raycr
This is on a 84 GW with the selector switch just under the dash. Somewhere there is a vacuum operated switch that turns on the indcater light in the dash and that is the switch that I'm looking for. Thanks
raycr is offline
post #4 of 4 Old 12-30-2003, 03:06 PM
jeepdaddy2000
1971 CJ5
The vacuum switch runs the fork motor on the transfer case. The light is run from a poppet switch above the fork rail. In order for the emergency drive light switch to activate, the shift rail must move to the lock position. You need to check to see that the emergency drive motor is working, there is power going to and from the light switch, and power going to the light.
Cannot locate neutral safety switch on 1987 Grand Wagoneer jedelbrock Full Size Jeep Forum 1 01-09-2010 06:54 PM
wagoneer/grand wagoneer differences? JeepnBlake Full Size Jeep Forum 1 08-26-2008 10:33 PM
78 Grand Wagoneer? aero mech Full Size Jeep Forum 2 12-30-2007 09:15 PM
Super Wagoneer 1968 Neutral Safety Switch SuperWagoneerVa Full Size Jeep Forum 2 10-25-2006 08:23 PM
Grand wagoneer grand cherokee engine- KWAG Full Size Jeep Forum 0 04-29-2005 07:55 AM
