'82 Wagoneer questions... - JeepForum.com
post #1 of 11 Old 07-12-2012, 11:03 PM Thread Starter
Digital10
I'm fixing up my '82 wagoneer and need a few answers.
First, where can I find out what emission equipment I can pull and how to do it?
Second, what are some great shocks I can put on to give me a nice small lift? I have Waggy sag...
Digital10 is offline
post #2 of 11 Old 07-13-2012, 01:18 AM
Puck81
Shocks dont "lift" only the springs do that. Shocks control the movement of the axle movement up and down and dampen it. To address the "Wag sag" there are 2 ways I can think of, an add-a-leaf to the the driver side spring pack, or lift springs. The lift springs are the better choice IMHO. Now for the smog, if its working properly by law it needs to stay on there. But since we all like more power, the air pump I believe is below the powerstearing pump. I cant help you with how to remove it, so sorry. Hope this helps a bit.
Puck81 is offline
post #3 of 11 Old 07-14-2012, 12:33 AM Thread Starter
Digital10
I will look into both of those suggestions...I know I need new shocks for sure. I will check the add a leafs. New to this stuff so any advice helps.
post #4 of 11 Old 07-14-2012, 06:37 AM
jasonprichards
Regarding the wag sag I just put spring overload shocks made by Gabriel on my 89 and it fixed the sag. I needed new shocks anyway so I killed 2 birds with one stone
jasonprichards is offline
post #5 of 11 Old 07-14-2012, 10:24 PM Thread Starter
Digital10
How do those work? I looked them up...thoughts?
post #6 of 11 Old 07-18-2012, 04:29 PM
TRIPPIN-CJ
I successfully removed all smog stuff from my '82 Waggie. Do you have the 360 V8? If so I would be glad to share what I did and what vacuum lines need to stay. There is one that is real important. If left off you will get 5 mpg guaranteed. Otherwise mine has been doing great and the engine compartment sure looks a lot better. Let me know if you want my input.
TRIPPIN-CJ is offline
post #7 of 11 Old 07-19-2012, 04:47 PM
jasonprichards
The spring overload shocks brought it back to it's original stance . That being said I probably only had about 2" of sag. It is a firmer ride than Jeep intended it to be but still floats down the road pretty nicely with no sag!
post #8 of 11 Old 07-19-2012, 08:36 PM Thread Starter
Digital10
I would live to hear and find out what you did...I do have the 360 V8. I don't even know where to start!
I checked out those shocks and I think I'm going to order them...I need new ones and want to boost the sag.
post #9 of 11 Old 07-20-2012, 09:24 AM
Zigged79
1979 FSJ Cherokee
I've gone to the spring shop and they re arched my original ones about 20 years ago and they are still up.
Zigged79 is offline
post #10 of 11 Old 08-09-2012, 11:18 PM
cwaugh369
Hey Trippin, what's that vacuum line you speak of? Just wanna make sure mine is intact....anything you can offer would be much apprec
cwaugh369 is offline
post #11 of 11 Old 08-10-2012, 12:27 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Do you need to smog check in your area?
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
