81 Wagoneer auto transmission problem - JeepForum.com
post #1 of 6 Old 04-06-2010, 07:49 PM Thread Starter
81Wagoneer
OK my Wagoneer runs, revs and idles fine. Up until this morning it drove fine as well. When I put it in drive and began to accelerate it basically bogs down when shifting from 1st to 2nd. It will still go but feels like the brake is being held down. Reverse works and if I shift it to 1st it will drive fine until I try to shift to second then the same thing happens, it doesnt want to go. Any ideas on what would cause this?
81Wagoneer is offline
post #2 of 6 Old 04-07-2010, 09:48 PM
thecommander
1978 FSJ Wagoneer
did you check the transmission fluid level
you would probably notice if your brakes were sticking because you would slow down everytime you let off the gas
the Sierra Club is GAY!!!
“The day will eventually come where people will respond the same way about Al Gore getting a Noble Peace Prize for Global Warming as they do now with Milli VaNilli getting a Grammy.”-my wife
thecommander is offline
post #3 of 6 Old 04-07-2010, 09:51 PM
thecommander
1978 FSJ Wagoneer
i'm not really great with automatic trannys. i'm sure i could rebuild one, but as far as diagnosing the problem for sure sorry.
you should have the 727
it could be the torque converter. i have a spare one i'll give you if you need it. just pay the shipping
check out
International Full Size Jeep Association - Powered by vBulletin
post #4 of 6 Old 04-07-2010, 10:11 PM
thecommander
1978 FSJ Wagoneer
another thing.
maybe your catalytic converter is plugged
post #5 of 6 Old 04-08-2010, 07:50 AM
megajeep
1989 FSJ Wagoneer
I had that exact symptom last week. It idled fine. 1st was fine, then when it shifted to 2nd if felt as if the brake was being press, then when it shifted back into first it let go and ran fine. Although I did not push very hard, it seemed that the more the accelerator was pressed the tighter it got.
I had the tranny pan off and did the rear band adjustment. But I missed a step and tightened it too tight. That was the result. I opened it back up and adjusted it properly and the problem went away.
It could be that the lock nut loosened and the band screw tightened itself. Self tightening is not unheard of. My motorcycle valves tighten every 3000 miles and needs periodic adjustment.
megajeep is offline
post #6 of 6 Old 04-08-2010, 08:22 AM
megajeep
1989 FSJ Wagoneer
Here is an applicable sentance from Tom Hand's guide to the Chrysler torqueflite automatic transmission.
Talking about how the bands work and modifications:
"This timing is very important; too early of a band release causes the engine to "rev up" until the front clutch is applied. Too late of a band release and/or too early of a clutch apply is more common; this gives a "putting on the brakes sensation" which is actually called shift overlap (Since the rear clutch is applied in both 1st and 2nd, and nothing has to be released, kickdown band timing is not as critical in the 1-2 shift)."
Who knows what other issues may cause this problem, but a band adjustment is pretty easy. You don't even need to put the jeep up on stands to do it. You would need a new gasket, socketwrench, 1/2" socket, something to catch all the fluid in, 11/16 box wrench, 5/16 8-point socket, and a torque wrench that goes as low as 72" pounds or 6' pounds. And a big piece of cardboard to slide around on and to keep the fluid off the driveway. Unless of course your threads holding the pan up strip out then that really sucks, requires a lot more tools, two more days, and a sore lower back.
megajeep is offline
83 wagoneer transmission bturnerexpress Full Size Jeep Forum 4 04-09-2008 02:36 AM
1983 wagoneer transmission problem m0oses Full Size Jeep Forum 5 09-11-2007 01:39 PM
81 wagoneer problem thomk172 Full Size Jeep Forum 3 04-20-2007 02:48 AM
81 wagoneer 360/auto CHEAP! Make an offer!! lmopar69 Full Size Jeep Forum 1 07-01-2004 05:31 PM
1991 Wagoneer Transmission Swap-Out L75 4 spd Full Size Jeep Forum 0 03-19-2002 07:27 AM
