81 J10 tune up - Page 2 - JeepForum.com
post #16 of 35 Old 03-27-2013, 11:14 PM
revelc
1985 FSJ Wagoneer
Originally Posted by Linkraver
yeah if i could afford a edelbrock intake and holly i would. but this is a daily driver.trying to get the best gas mileage
Buy mine. I'm in the Springs. My 401 had a performer and I just got a Holley T/A. Still have the other Holley 4-bbl too.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #17 of 35 Old 03-28-2013, 07:38 AM
super98lsc
Properly tune 4 barrel should get better mileage than the 2. Smaller bores so higher velocity air charge.... Until you get addicted to the go pedal. I bet you already know this but make certian the machine shop runs a ball hone through those lifter bores. the second a new lifter stops rotating in its bore = good bye cam lobe. If you can afford new springs use them, im not big on trusting 40 year old valvesprings. Least not in GM stuff.. Nice rig btw!
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #18 of 35 Old 03-28-2013, 11:25 AM Thread Starter
Linkraver
1981 J-Series Truck
Hhhhhmmmmm I need to find some cash I guess lol what size is ur carb revelc??
Linkraver is offline
post #19 of 35 Old 03-28-2013, 11:48 AM
revelc
1985 FSJ Wagoneer
Honestly I don't know EXACTLY but it's between a 600-750. It got my 360 to Colorado 85-90 mph no problem and never stumbled off the line.
The only reason I got the new one is because I thought it gelled up on the road so I got a new carb. It was just a leaking fuel line.
I replaced it with a 670 Holley TA.
revelc is offline
post #20 of 35 Old 03-28-2013, 03:34 PM
super98lsc
revelc, just curious on the compression you used... I built my 4.7 Stroker in the WJ@ 9.6:1 static but im fabricating a turbo/intercooler setup for 15psi etc. With a healthy cam (not sure of your specs) but cant we get away with 10.5:1 on the 360/401 if we are running 93 octane? I know BBC are NOT tolerant of high compression so 9:5 with iron heads on them is about it on pump gas. Id rather not have to pony up for aluminum heads but i might.... from what i hear the Edelbrocks dont really flow any better than cleaned up stockers.
post #21 of 35 Old 03-28-2013, 08:05 PM
revelc
1985 FSJ Wagoneer
Im running regular grade on my 9.5:1 I don't know my dynamic compression with my cam though.
From what I hear 10:1 is about where you start waking the line. If your on the road and the fill stations out of primo, you could be in trouble.
I can provide my can specs of you want later. It's a crowed stage 2-3 grind.
revelc is offline
post #22 of 35 Old 03-28-2013, 09:33 PM
RockRollin
1990 FSJ Wagoneer
I was checking into Saul's cam, the comp 260 grind. He bough the kit with chain and gears. That kit has a centerline of 106, instead of the factory 110. So if your using that kit it will not be retarded as the factory spec calls for.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #23 of 35 Old 03-28-2013, 09:46 PM
revelc
1985 FSJ Wagoneer
I was thinking that the aftermarket companies compensated the retardation but didn't want to open a can of worms. Thanks for sharing.
revelc is offline
post #24 of 35 Old 03-28-2013, 10:26 PM
RockRollin
1990 FSJ Wagoneer
Most of the "performance" company's do, but not all. Edelbrock goes both ways. The comp seems to be the main one that does it in the grind instead of the gears. I like to throw it out there. If you mix and match, you could end up at 102cl which would be a real pita to tune for street. It would be nice if the cam company's would just spell it out. Alas for many of us, our good intentions lead to higher education LOL.
"I like fun" Edd
post #25 of 35 Old 03-29-2013, 02:40 PM Thread Starter
Linkraver
1981 J-Series Truck
Well I ordered my comp cams small kit today. Should be here Tuesday or Wednesday :-) I got the 260h. So will I have to degree my cam n stuff. Or am I ok since I'm using factory crank n stuff??
post #26 of 35 Old 03-29-2013, 05:16 PM
revelc
1985 FSJ Wagoneer
You'll be okay because Comp factors in the retarding. Keep us posted on your progress. Your really tearing into that thing.
revelc is offline
post #27 of 35 Old 03-29-2013, 05:26 PM Thread Starter
Linkraver
1981 J-Series Truck
That is an understatement lol I dropped the block n heads off to get hot tanked yesterday :-) waitin to find out if I need bigger rings or bearings from the machinist :-) I'm thinkin about getting an edlebrock intake just for ****s and giggles. My friend has a nice Holley he is willin to give me for some work on his truck :-):-):-)
post #28 of 35 Old 03-29-2013, 06:57 PM
revelc
1985 FSJ Wagoneer
I have a performer intake I'm getting rid of. And a 260 cam and lifters with timing gear with less than 2,000 miles on them if your interested. And a Holley 4-BBL too.
Shameless plug :-)
revelc is offline
post #29 of 35 Old 04-08-2013, 03:22 PM Thread Starter
Linkraver
1981 J-Series Truck
and yet another update. so i took my block, crankshaft n heads to a machine shop to get cleaned and checked. Crankshaft needed turned .010", block .030 over and the head is ok. going to tear down the head and check the valves and replace the seals. Ordered all new pistons, rings, main n rod bearings yesterday. man this puppy is going to rock the socks off this truck!!!! But i may have found another toy a 74 j20!!! so i have a thousand gears turning at this point hehehehe
post #30 of 35 Old 04-08-2013, 04:11 PM
revelc
1985 FSJ Wagoneer
Awesome man! So excited for you! What compression ratio pistons did you go with?
revelc is offline
