79 Wagoneer - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > 79 Wagoneer
VIAIR compressors at ROCKRIDGE4WD!! DEALS INSIDE!50" LED CREE Light Bar Pair With Wiring KitIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 10-31-2014, 07:41 PM   #1
gixxerphil
gixxerphil's Avatar
79 Wagoneer
This is going to be a slow build and a way to keep progress of what's been done.
I started with a $1200 Waggie from Tn. The only cancer was in the back floor board right in front of the passenger seat.
This is what I started with.
Back seat
The only rust through
I bought it knowing that the rear window motor needed to be replaced and the window needed to be put back in. I decided to buy a new window lifter, side glass channels, motor and a window cushion.
m416 trailer build
TJ Tech BOOT CAMP
TJ SPECS
Originally Posted by elephantrider View Post
can you get a good pic of your muff set up ?
gixxerphil is offline   Reply With Quote Quick reply to this message
Unread 10-31-2014, 07:48 PM   #2
gixxerphil
gixxerphil's Avatar
It sat like that for a year, then I let a mechanic do a complete tuneup........Little did I know, a motor rebuild was needed.
I bought a new starter, as the old one was shot.
With the motor getting a rebuild, I decided to upgrade some things.
I bought a TFI upgrade
New POR-15 engine paint kit in Chyrsler blue
While the motor was out, I decided I might as well paint the engine bay.
m416 trailer build
TJ Tech BOOT CAMP
TJ SPECS
Unread 10-31-2014, 07:51 PM   #3
gixxerphil
gixxerphil's Avatar
Pics of the motor before the rebuild
Reason for the rebuild
m416 trailer build
TJ Tech BOOT CAMP
TJ SPECS
Unread 10-31-2014, 07:58 PM   #4
gixxerphil
gixxerphil's Avatar
Driver fender before and after. It's not show quality, but it's better than it was
I used Rustoleum primer and semi-gloss black. I sprayed the fender wells with Rustoleum truck bed coating
Passenger fender done
Truck bed coating
m416 trailer build
TJ Tech BOOT CAMP
TJ SPECS
Unread 10-31-2014, 08:02 PM   #5
gixxerphil
gixxerphil's Avatar
I decided to buy a new Mopar aluminum intake
Holley Street Avenger 670 carb
Aluminum radiator and new hoses
I also bought a new flexplate, Hedman headers, ignition control module, water pump, master brake cylinder, and I'm sure a few more things I can't remember right now.
m416 trailer build
TJ Tech BOOT CAMP
TJ SPECS
Unread 10-31-2014, 08:06 PM   #6
gixxerphil
gixxerphil's Avatar
Specs on the Waggie are 360, TH400, Quadratrac, D44's F/R.
My eventual plans are to run a 4" lift with 33x10.5 on the stock steelies with a set of Jeep dog dishes. Paint will be black with a white roof and white stripe where the woodgrain sticker is. I want this to be a good camping/dog hauler and something I don't mind driving anywhere.
m416 trailer build
TJ Tech BOOT CAMP
TJ SPECS
Unread 10-31-2014, 08:25 PM   #7
gixxerphil
gixxerphil's Avatar
I bought a 20lb sand blaster from harbor freight about 3 years ago, I finally put it together tonight with the hopes I can use it on some of the parts I still need to paint.
m416 trailer build
TJ Tech BOOT CAMP
TJ SPECS
Unread 11-01-2014, 10:31 AM   #8
lindel
Body looks to be in good shape, and it looks like you're doing things right. I'm looking forward to seeing where you take this.
Lindel
His: 1999 TJ Sport
Hers: 1987 Grand Wagoneer
lindel is offline   Reply With Quote Quick reply to this message
Unread 11-02-2014, 10:56 PM   #9
gixxerphil
gixxerphil's Avatar
I must admit, I'm a little proud of myself(pats myself on back) This is the first vehicle I've done this much work on, it's gratifying to see it change like it has. I still have a long way to go and a lot of questions left
m416 trailer build
TJ Tech BOOT CAMP
TJ SPECS
Unread 11-03-2014, 10:18 AM   #10
lindel
I'll also recommend www.fsjnetwork.com and www.ifsja.org . Both are FSJ specific sites.
I'm looking forward to watching your build. I plan on putting fuel injection on the wife's 87, but probably not till spring. (it gets a bit chilly in these parts!)
I'm always on the hunt for a Cherokee WT, but doubt I'll find one worth messing with up here.
Lindel
His: 1999 TJ Sport
Unread 11-03-2014, 12:57 PM   #11
Dr. Marneaus
Station Wagoneer
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
Sounds familiar lol.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread: Marns '73 Wagoneer Thread ----- The Camper Build Thread: Marns 1980 Jayco JayFinch6 Build Thread
Dr. Marneaus is offline   Reply With Quote Quick reply to this message
Unread 11-03-2014, 01:59 PM   #12
lindel
Doc, is that a picture of Phoebe II?
Lindel
His: 1999 TJ Sport
Unread 11-03-2014, 03:20 PM   #13
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
I'm not sure what you're referring to?
-Andrew
Unread 11-03-2014, 04:16 PM   #14
lindel
Your avatar. Looks like Krista's Phoebe II.
Lindel
His: 1999 TJ Sport
Unread 11-03-2014, 04:27 PM   #15
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Who is Krista? It's my jeep.
-Andrew
