79 J10 Transfer case, motor mounts broke - JeepForum.com
post #1 of 3 Old 10-23-2008, 08:41 PM Thread Starter
j10driver
1979 J-Series Truck
I was out playing and broke both motor mounts, which isn't the biggest problem. Unfortunantly the mounting tabs on the transfer case broke also. Is there a good solution to fix this? and is it worth putting replacement motor mounts or fabricating solid mounts? The motor is the amc 360, aluminum intake, hei distrib and headers, so there is a little bit of power. Thanks for your time....jb
j10driver is offline
post #2 of 3 Old 10-24-2008, 09:41 AM
BJ's Off-Road
1979 FSJ Cherokee
Solid mounts would vibrate you like mad and would probably break more stuff than before. Polyurethane would probably be the best way to go:
Motor Mounts:
http://bjsoffroad.com/cartgenie/prod...p?pid=42&cid=3
Tranny Mount:
http://bjsoffroad.com/cartgenie/prod...p?pid=56&cid=4
THanks.
www.bjsoffroad.com
BJ's Off-Road is offline
post #3 of 3 Old 10-26-2008, 12:44 AM
carnuck
1984 J-Series Truck
I wrapped a strap around the tcase to keep it from moving when I ripped the mounting flange off for the mounts.
carnuck is offline
frame warpage or motor mounts ? riotstarter Full Size Jeep Forum 3 12-08-2009 08:04 PM
what transfer case ? CajunCountry Full Size Jeep Forum 1 06-17-2009 05:56 PM
Which transfer case with T18-1B? poppaw-2 Full Size Jeep Forum 3 06-04-2008 01:13 AM
What transfer case do I have? Please help! 2manykids4a7 Full Size Jeep Forum 4 07-20-2006 08:29 AM
what transfer case????? COYOTE501 Full Size Jeep Forum 2 02-20-2006 10:47 PM
