79 cherokee chief - JeepForum.com
post #1 of 24 Old 08-06-2012, 06:32 PM Thread Starter
93ZJDave
79 cherokee chief
So I got a 79 cherokee chief from my uncle he started building it back in the 90s and just never finished it and wants to seem it finished so now I have it. The motor is a 360 bored 30 over and cammed but it hasn't ran since rebuilt 20 years ago. I tried turning it over by hand but no go. I pulled the plugs and soaked the cylinders with some penatrating oil and letting it sit are there any other tips to help me get it turned over? It was also a frame off resto so the frame and floor are all sand blasted and rubber coated if there are any tips that would help me with this project please let me know. Thanks here are a few pics of it im determined to get it going and im aware of the amount of time I will have to invest in it.
2012-08-06_19-23-25_102.jpg   2012-08-06_19-39-18_170.jpg   2012-08-06_19-23-45_680.jpg   2012-08-06_19-48-47_466.jpg
93ZJDave is offline
post #2 of 24 Old 08-08-2012, 12:32 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Nice, looks like it'll be a fun project.
good taste in jeeps, bad taste in beer haha.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #3 of 24 Old 08-08-2012, 03:39 PM Thread Starter
93ZJDave
Im loving it but the motor seems to siezed up pretty good its soaking in pb blaster so i hope it breaks lose but tge jeep has 66k miles tge motor has 0 i was rebuilt bored 30over and cammed it was for alittle then it was put in the jeep and sat for 20 years whats the best way to break the motor free.
93ZJDave is offline
post #4 of 24 Old 08-08-2012, 07:21 PM
TikiWagon
1989 FSJ Wagoneer
Automatic transmission fluid in the cylinders and a good heat lamp on each side of the block. We loosened a '55 Ford six that had been sitting from 1979 till 2010 that way.
Heap o Jeep... and over 2 ton o fun...
TikiWagon is offline
post #5 of 24 Old 08-08-2012, 07:23 PM Thread Starter
93ZJDave
So today i pulled a valve cover and i didnt like what i seen the push rodz were rusted bad its been a long time doing anything that sat this long should i try to save this motor? Or build a new one i think it might be saveable if i pull the heads but who knows til i get it apart.
93ZJDave is offline
post #6 of 24 Old 08-08-2012, 07:25 PM Thread Starter
93ZJDave
Ill try trans fluid after i get the pb blaster out lol. Would it be ok to pretty much soak the entire motor in trans and maybe drain the oil and that with trans fluid to
93ZJDave is offline
post #7 of 24 Old 08-08-2012, 07:32 PM
TikiWagon
1989 FSJ Wagoneer
Couldn't hurt at all. Seen a few engines preserved by filling 'em almost full of trans fluid. It's pretty versatile stuff. I use it as a lead substitute in my '55 Chevy truck too. Bonus: it keeps the carb clean along with everything else. Just "cheap" Dexron is all you need, has the least friction modifiers in it.
post #8 of 24 Old 08-08-2012, 07:37 PM Thread Starter
93ZJDave
Ok sounds good ill drain the 20 year old oil out and fill it wit trans the motor pretty much went from the shop where it was built to the jeep where it sat the pistons didnt even have carbon on em thats probably the worst thing u can do to a fresh engine is let it sit that long ive also been told kerosene works wonders to.)
93ZJDave is offline
post #9 of 24 Old 08-08-2012, 07:47 PM
TikiWagon
1989 FSJ Wagoneer
Yeah, kerosine is a fuel oil, it lubricates almost as well as it cleans. It's the main ingredient in engine flush too. Rinsed my entire rear diff in it when I rebuilt it last month, came out clean as could be with a little scrubbing inside and out, and didn't hurt what was left of the paint.
post #10 of 24 Old 08-09-2012, 01:12 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
if the engine was sitting for 20 years without having been prepped, you've probably got a bit of work ahead of you. I'd pull the heads and get a look.
drop the pan and get a look too, i'd hate to see what everything looks like under there.
-Andrew
Marn is offline
post #11 of 24 Old 08-10-2012, 10:26 AM
TikiWagon
1989 FSJ Wagoneer
Always a good idea, and if you're feeling really ambitious, don't be afraid to pull the heads for a peek too.
post #12 of 24 Old 08-18-2012, 05:11 PM Thread Starter
93ZJDave
Ok so a week went by with me dying inside to mess with it but i needed to let it soak in pb blaster i tried today still no luck but i was bored so pulled the passenger side head off it came apart like butter no effort at i was amazed but wheb i got the head off i was alittle scared with the. Amount of rust in the cylinders but i tapped each piston with a small piece of work and she moved!! So i worked it back and forth slow wiping the rust out and spraying more pb in now it makes a full turn man that made my day to see it turn it was pretty discouraging after pulling the head off and seeing it.
93ZJDave is offline
post #13 of 24 Old 08-18-2012, 05:13 PM Thread Starter
93ZJDave
The first pic is when i first pulled the head the second if once it was freed up and cleaned alittle
93ZJDave is offline
post #14 of 24 Old 09-06-2012, 07:34 PM Thread Starter
93ZJDave
So i got everything cleaned up on the chief and got a nice deal on an edelbrock intake manifold for 75 bucks for it but before any of that i drained the 22 year old oil out and well i got about 2 quarts of water out of the oil pan. I guess when it rains it pours lol the motor is free and turns over and the cylinders are nice after i re honed them. I have to pull the oil pan and check it out more before trying to start it. I hate to change the factory intake and carb but my uncle has a golden eagle all original and hes having issues with the car so i wanna make it more driveable that and with it being bored out to a 392 and cammed as big as it could go back in 1990 it needs to breathe more so a nice intake and 4 barrel carb and maybe a set of long tube headers. I plan on showing the jeep i dont want to beat it in the woods or anything just take it to shows for people to appreciate it.
93ZJDave is offline
post #15 of 24 Old 09-06-2012, 08:02 PM
pleontks
1976 J-Series Truck
go get a ford. let the jeep live where it's supposed to. Not penned up in a trailer.
Beauty is in the eye of the jeepowner.
pleontks is offline
New to me 77 Cherokee Chief pleontks Full Size Jeep Forum 122 11-02-2014 07:32 PM
77 cherokee chief jimony8 Full Size Jeep Forum 2 07-06-2012 08:39 AM
'86 Cherokee Chief Cherokeechief86 Full Size Jeep Forum 9 12-28-2010 03:17 AM
Cherokee Chief XJ99 Full Size Jeep Forum 4 05-01-2004 08:51 PM
78 or 87 cherokee chief dzp Full Size Jeep Forum 0 02-24-2003 07:09 PM
