78 wagoner SOA - JeepForum.com
post #1 of 4 Old 04-25-2013, 04:41 PM Thread Starter
Purdydirty1
78 wagoner SOA
Hey guys new here. I've got a 78 wagoner with 360 and we are going to do a SOA tomorrow just looking for some pointers. About what do yall set your pinion angles to.
Purdydirty1 is offline
post #2 of 4 Old 04-26-2013, 06:16 AM
muddy93
1987 FSJ Wagoneer
I’m going to assume that you are talking about the front axle since the rear is already SOA. I’d be more concerned about the caster angle rather than the pinion. Just set the new perches parallel to the stock ones and you should be good to go.
If you happen to be referring to the rear axle; Where you set the pinion angle will depend on what type of drive shaft you will be running.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #3 of 4 Old 04-26-2013, 07:42 AM
CSP
Yep, caster is more important than pinion in front. The advice to make your spring over perches parallel to the spring under is spot on.
CSP is offline
post #4 of 4 Old 04-26-2013, 07:17 PM Thread Starter
Purdydirty1
That's what I thought but I was getting conflictive information
