78 cherokee starting problem - JeepForum.com
post #1 of 4 Old 03-28-2007, 07:05 PM Thread Starter
PriceP64
I own a 78 cherokee with the 285 in line 6 and put a new starter in it, well now it won't start, i have power and i have a spark but for some reason it won't crank over, any advice/help would be greatly appreciated.
PriceP64 is offline
post #2 of 4 Old 03-28-2007, 09:47 PM
apexjeepinjoe
Sounds like a ground problem or maybe a solenoid.
~Joe~
2012 Wrangler Rubicon(my woman's ride)
2002 Wrangler Apex Edition(with lots of goodies)
1988 Comanche(stock for now)
1970 Jeepster Commando(a work In progress)
apexjeepinjoe is offline
post #3 of 4 Old 03-30-2007, 04:45 PM Thread Starter
PriceP64
I have a new starter in the Jeep... a new alternator... and I just replaced the battery cables... I am getting power, but there is still not enough to turn over the starter. I had a mechanic look at it and he could not even figure the problem out... so i am not sure what I should do now... any suggestions??
PriceP64 is offline
post #4 of 4 Old 04-25-2007, 01:02 PM
mafos4471
Is the starter grounded to the frame or batt? If you hear a click and no crank, possible sticking solenoid, there is also a wire that goes to the coil form the "S" terminal on the starter I believe. No click when turning key=bad conections.
mafos4471 is offline
Start Problem on 89 Cherokee XJ mybrosride Full Size Jeep Forum 6 08-03-2009 08:10 PM
85' 360 not starting Nikolaiswiss Full Size Jeep Forum 1 05-16-2009 06:31 PM
cherokee brake problem srandallf Full Size Jeep Forum 2 04-27-2007 01:19 PM
90 V8 Grandwagoneer starting problem DRLANNETTI Full Size Jeep Forum 3 12-23-2004 11:05 PM
Need help with starting issue stone5150 Full Size Jeep Forum 2 07-25-2004 11:26 PM
