a '73 wagoneer that wasn't - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > a '73 wagoneer that wasn't
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 06-16-2013, 02:58 PM   #1
jetsetter57
1974 FSJ Wagoneer
Bought a 73 wagoneer on 35's and 4" lift with a 383 and th400. Turns out with some engine and VIN decoding it's actually a 350 engine th400 trans and a 1974!
Being a 74 seems to be a blessing for parts, whew dodged a bullet there. Here is the VIN/engine codes if anyone can back me up
Replacement identification number
J4A154CZ08848
control number
372671
Engine casting block #
3970010
engine ID code #
V1116TFW
The RIN seems like it could be suspect but the grille and tailgate seem to match other pics of the 74. Any help or backup would be great, Thanks!
jetsetter57 is offline   Reply With Quote Quick reply to this message
Unread 06-16-2013, 03:46 PM   #2
pleontks
1976 J-Series Truck
pics would help
Beauty is in the eye of the jeepowner.
pleontks is offline   Reply With Quote Quick reply to this message
Unread 06-16-2013, 06:28 PM   #3
CSP
The 4 following the J in the VIN says it's a '74.
CSP is online now   Reply With Quote Quick reply to this message
Unread 06-16-2013, 06:41 PM   #4
jetsetter57
1974 FSJ Wagoneer
So what's a replacement identification number? Especially 13 numbers instead of 17. I'm assuming that's because it's older than a certain year? How trustworthy is the RIN versus the actual VIN?
Unread 06-17-2013, 09:11 AM   #5
CSP
The tag actually says "Replacement"?
VIN numbers weren't 17 digits until the 1980s.
Unread 06-17-2013, 12:30 PM   #6
Dr. Marneaus
Station Wagoneer
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
A 1974 would not have come with a 350. Period. They used the Buick 350 back in the day, but not in 74.
The Turbo400 was the auto tranny used back then. The early ones like mine were a "nailhead" pattern, which used an adapter ring to get a generic transmission bolt pattern to bolt up to numerous engines. In 94 they switched to using an actual AMC pattern bellhousing on the transmission case.
That 350 isnt stock.
The sad thing, according the the 8th digit in that vin, is your truck originally came with a 401. Now it has a 350 that somebody dropped in there.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread: Marns '73 Wagoneer Thread ----- The Camper Build Thread: Marns 1980 Jayco JayFinch6 Build Thread
Dr. Marneaus is offline   Reply With Quote Quick reply to this message
Unread 06-17-2013, 10:24 PM   #7
jetsetter57
1974 FSJ Wagoneer
Yeah, I saw the 400ci number. What a shame. The next mystery is that the previous owner "says" it's a 383. Now the drop of the oil pan is next to try and determine that fact. I suppose. But lucky day on the '74.
Unread 06-17-2013, 10:40 PM   #8
jetsetter57
1974 FSJ Wagoneer
Check the gallery pics, that's all I can figure out for photos for now.
Unread 06-18-2013, 12:53 AM   #9
super98lsc
a 383 is a stroker 350 ie a 400 Chevy stroke in an .030 over 350 block. Good engine when done correctly. As jetsetter said above you will need to drop the pan and measure the stroke or look for where the block was clearanced along the pan rail to clear the crank throws.
www.mangierisrc.com
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline   Reply With Quote Quick reply to this message
Unread 06-18-2013, 01:34 PM   #10
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
when you hit 30 posts you can post pictures.
You can attach the files to your posts here, or you can use a site like photobucket.com to upload them and just link them.
-Andrew
