72 Wagoneer rear axle removal - JeepForum.com
post #1 of 9 Old 11-27-2005, 04:27 PM Thread Starter
tommy b
1956 CJ5
How do I get the rear axles out of a 72 Wagoneer? Do I need an axle puller? I was told there might be a pin or snap ring inside the punkin that holds the axle in. I need to remove the axles to take off the brake backing plates. Thanks for any info.
tommy b
'56 CJ 5, 283 Chevy V8 Powered
Road? Where we're going we don't need roads.
Dr. Emmett Brown
tommy b is offline
post #2 of 9 Old 11-28-2005, 10:38 AM
J4GRAND
No pin or snap ring holding the axles on. You have to remove the plate at the end of the axle tubes that has 4 or 5 (I can't remember exactly) bolts. You access the bolts throught the hole in the axle end. You may need a puller, but a common trick is to reverse the brake drum, put on the lug nuts a little, and use the drum as a slide hammer. Unless the outer axle bearings are really buggered up, this should do the trick.
Patrick V.
Valparaiso, IN
73 Jeep J4000 360 .040 over, Summit K8600 Cam, Edelbrock Manifold and 750CFM 4V TH400/1339 QT
78 Cherokee Chief- Hunting Property Rig
05 Grand Cherokee- 3.7 V6 5 speed auto
J4GRAND is offline
post #3 of 9 Old 11-28-2005, 01:41 PM Thread Starter
tommy b
1956 CJ5
Thanks. What I was worried about was having to get into the differential to release the axle. I've got a 5# slide hammer puller. The plate that attaches to the axle flange is almost flat so unless there's a hub sticking out past the flange (like on my 56 CJ5) it should work. I'm headed to the library to look up the specifics on 72 wagoneers. Pictures always help.
tommy b
Dr. Emmett Brown
tommy b is offline
post #4 of 9 Old 11-28-2005, 06:42 PM
jode
Arent the axles in a 72 2-piece? If so, wouldnt that method not work?
Hung like Einstein and smart as a horse...
90 YJ, 2.5L, 5-speed
jode is offline
post #5 of 9 Old 11-29-2005, 04:33 AM Thread Starter
tommy b
1956 CJ5
I looked at a Haynes manual on the 72 Wagoneer yesterday and it seemed like a straightforward removal like J4 GRAND said above. I'm about to find out because in about 6 hours I'm leaving for the junkyard to pull them. It's 10 degrees outside now, supposed to go to the 40's tomorrow and then turn colder again on Wednesday so I've got to make my move before someone else bags them. I'll let you know how it all turns out. Thanks for all the help.
tommy b
Dr. Emmett Brown
tommy b is offline
post #6 of 9 Old 11-29-2005, 09:19 AM
J4GRAND
No Jode, they are not. The two-piece, 19 spline Dana 44s were done after 1969. In '70, they went to the one-piece, 30 spline Dana 44.
Patrick V.
Valparaiso, IN
J4GRAND is offline
post #7 of 9 Old 11-29-2005, 09:37 AM
jode
Good times
jode is offline
post #8 of 9 Old 11-30-2005, 11:10 AM Thread Starter
tommy b
1956 CJ5
First, I want to thank everyone for the helpful information. Second, I have to say the removal job was a snap. Thanks to the dry Colorado climate, I didn't even need a puller to get one rear axle off. It just slipped off by hand. Did have one scary moment, though. The other rear axle had a rubber plug in the access hole for the bolts behind it. With all the dirt and crud on it, it looked like solid steel. There were two marks that looked like they could be a hole. I tapped on one with a wrench and it was solid steel. Didn't know how the heck we were going to get to those bolts. While I was taking off the front backing plates, my buddy was working on the rears. After a few minutes he told me that he discovered the rubber plug. No sweat after that.
Also, I picked up the set of Warn manual lockers from the vehicle since they were in such good shape. I don't know if they'll fit my 56 CJ5 or not. If not, you'll see them posted in the items for sale section. Thanks again for the help. Great forum
tommy b
Dr. Emmett Brown
tommy b is offline
post #9 of 9 Old 12-01-2005, 05:57 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
tommy b
Don't think they're gonna work. The 27 front axle in the 56 has a different spline count.
jeepdaddy2000 is online now
76 wagoneer rear axle rodimusprime Full Size Jeep Forum 5 07-02-2009 05:16 AM
93 Wagoneer dash removal 2slw4u Full Size Jeep Forum 5 07-19-2008 05:12 PM
Jeep Wagoneer axle question Bclevy Full Size Jeep Forum 2 12-04-2007 08:42 PM
84 wagoneer axle swap jumpmonkey77 Full Size Jeep Forum 2 02-02-2007 09:20 AM
1989 Grand Wagoneer Radio Removal bmcalear Full Size Jeep Forum 1 07-22-2003 07:53 PM
