post #1 of Old 04-16-2013, 05:35 PM Thread Starter
Millhouse
1970 FSJ Wagoneer
70 Wagoneer Tranny Slippage
Hey gang. So, now that the Waggy is running top notch, the tranny has started to slip. I have reverse, and when I put it in drive, it doesn't want to shift up. The fluid is at a good level and seems to look clean.
Any suggestions?
Thanks!
Millhouse is offline
post #2 of Old 04-16-2013, 11:47 PM
Dr. Marneaus
Station Wagoneer
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
Rebuild it.
if you choose to DIY, a Turbo400 kit is like $250 plus maybe $50 in fluid and $90 for a torque converter.
http://www.summitracing.com/parts/sum-705021
If you choose to have it done by a shop, it'll be somewhere in the ballpark of $700-$900 most likely.
only other thing I can suggest is checking the governor, but that seems less likely.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread: Marns '73 Wagoneer Thread ----- The Camper Build Thread: Marns 1980 Jayco JayFinch6 Build Thread
Dr. Marneaus is offline
post #3 of Old 04-17-2013, 02:56 AM
RockRollin
1990 FSJ Wagoneer
Check the vacuum modulator. Also the governor could be apple cored.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #4 of Old 04-17-2013, 01:28 PM
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
even without the vacuum modulator disconnected the thing should still shift.
-Andrew
post #5 of Old 04-17-2013, 01:38 PM
RockRollin
1990 FSJ Wagoneer
It doesn't downshift due to high vacuum conditions. Low vacuum can hold it in first.
I'm at 90% on the governer anyhow.
"I like fun" Edd
post #6 of Old 04-21-2013, 07:19 AM Thread Starter
Millhouse
1970 FSJ Wagoneer
RockRollin was correct. Thanks dude! The vacuum line from the intake to the modulator practically crumbled when I took it off. Must have been sucking air.
It works great and am sure glad I don't have to rebuild it. (yet)
Dr. Marneaus- You're an LA? Me too. Great profession.
post #7 of Old 04-21-2013, 08:01 AM
RockRollin
1990 FSJ Wagoneer
I like a low dollar fix for what seems like a high dollar malfunction.
"I like fun" Edd
post #8 of Old 04-21-2013, 12:02 PM
revelc
1985 FSJ Wagoneer
X2 Makes me want to fist pump for people when it happens.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #9 of Old 04-21-2013, 07:48 PM
ghcoe
1977 FSJ Cherokee
That is why I work on my own vehicles. They would have told you it was a bad transmission and charged you a rebuild even if they did find the simple problem.
George.
1977 Jeep Cherokee Chief, 1972 360cid., Turbo 400 , Quadra Trac with Low Range reduction, 3:31 Gears, 31x10.5-15 GT Radial Adventuro AT II. Factory Brush Guard/Spare Tire Carrier/Safari Kit/Tow Package.
http://www.jeepforum.com/forum/f57/1...chief-1749666/
ghcoe is offline
post #10 of Old 04-24-2013, 08:13 PM
super98lsc
Good call! caught this late had same issue in the Stingray when the damned line came off after a hard launch, I thought I smoked some more hard parts such a great feeling when you find out its not. My worse was an honest mid 10 sec 383 IROC-Z, I dragged a Viper at the Texas Motorplex and won... idling off the track I feel vibrations, missfiring, and worse a nasty death knock. Turned out I ripped the trans crossmember right out of the lousy F body paper thin "frame" and the trans was hanging by 3-4 threads of 1 of the 4 bolts. It knocked the HEI off when the engine tilted back to the firewall. We screwed it back in with 4 self tapping screws and drove it home. Later installing a huge plate on the interior under the carpet then bolting the trans through it to distribute the load. I thought I had just lost a 10k Rher-Morrison 383.
www.mangierisrc.com
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #11 of Old 04-25-2013, 05:10 AM
revelc
1985 FSJ Wagoneer
I would have dropped to my knees and thanked God on that one
revelc is offline
You may not post new threads
You may not post replies
