68 Grand wagoneer Question - JeepForum.com
post #1 of 10 Old 02-21-2010, 11:08 AM Thread Starter
Rokjeep
I came across a 68 Grand wagoneer motor, trans, and t-case. I was told it was a 327 V8(Chevy motor w/ jeep heads), The trans. is a jeep version of a turbo 400( it measures up to a turbo 400 for input shaft to out put shaft and the same bell housing as a turbo 400), and the T-case is a T-18. my question is was there a such animal?
Rokjeep is offline
post #2 of 10 Old 02-21-2010, 11:51 AM
Jason
If it's a 327 from around those years, its an AMC. It could be a Buick 350, as those were found around that year.
T-18 is a transmission, not a transfer case. A Dana 18 perhaps?
Jason is offline
post #3 of 10 Old 02-21-2010, 02:23 PM
WaveHunter
1981 FSJ Wagoneer
Jason is right. AMC 327 and Dana 20 t/c.
Texas Full Size Jeep Association (TxFSJa.org)
WaveHunter is offline
post #4 of 10 Old 02-21-2010, 04:37 PM
gnarlytoes
1977 FSJ Cherokee
The AMC TH400 transmission is almost the same as the GM TH400. The housing has the AMC bolt pattern instead of GM. The internals are the same. All I've ever seen even have GM stamped pans.
gnarlytoes is offline
post #5 of 10 Old 02-21-2010, 08:07 PM
carnuck
1984 J-Series Truck
Actually, it has a factory adapter ring. The trans is a Buick nailhead TH400 (different from Chev or the BOP pattern used in later GMs)
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #6 of 10 Old 02-21-2010, 10:15 PM
BJ's Off-Road
1979 FSJ Cherokee
Also, it isn't a Grand Wagoneer, it is a Wagoneer.
The Grand Wagoneer didn't start production until 1984.
Carnuck is correct, it is a Buick Nailhead pattern with an adapter ring.
www.bjsoffroad.com
BJ's Off-Road is offline
post #7 of 10 Old 02-23-2010, 05:30 AM
greenbeater
greenbeater's Avatar
1968 FSJ Wagoneer
not sure what that one has in it but like others have said mine (also a 68) had the 350 buick with adapter, to a 400 turbo with a d20 t-case if you can take a look at them you could compare with the pics in my build thread to see if they are indeed the same parts.
his - 68' Wagoneer, 455 Pontiac, tons
hers - 00' XJ tail rig D44, C9.25, 4.56
ours - 01' WJ 4.0
greenbeater is offline
post #8 of 10 Old 02-25-2010, 10:52 AM Thread Starter
Rokjeep
Motor, trans, and T-case for sale! make offer
Rokjeep is offline
post #9 of 10 Old 02-25-2010, 12:29 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Try listing them in the JF Classifieds.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #10 of 10 Old 03-07-2010, 09:46 PM
Grape Ape
Web Wanker
Grape Ape's Avatar
Rokjeep that could be a 327 it was an AMC motor called the Vigilante. It was a well proven motor that had been in use in the Nash rambler as a 250 cubic inch motor. It was bored and stroked to 327 in 1965 for use in the Wagoneer. It put out 250 horsepower. 1968 was the last year it was used and it was only used in the Wagoneer that year and in no other vehicle. In 1968 they started using the Buick Dauntless 350 V8 It was basically a 225 v6 with 2 more cylinders. It had less horsepower than the 327 but more torque so the seat of the pants feel with the 350 was much better and people liked it better. The 350 was available until 1970 in the Kaiser line, then was replaced by the AMC motors in 1971. The 350 was available as a special order for about half of 1971 (had to get rid of the ones on the shelves.)
The tranny would be the TH400 as mentioned above and the t-case is a 2 speed spicer 20. It is a nice t-case and is easily modified into a twinshifted case.
EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun!
We've idiot proofed the world... now its full of idiots. - Spiritof76
You will truly be the same today as you will be five years from now, except for two things, the people you meet and the books you read. Charles E. Jones
I think I'll add some memorable quotes. blah blah blah..... FPKites
Trying to understand some people, is like trying to pick up a turd by the clean side.
Grape Ape is offline
Shock absorber question for 89 Grand Wagoneer TurboM3 Full Size Jeep Forum 5 08-06-2009 12:42 PM
Here's a really stupid axle question for you grand wagoneer guys yj_beater51 Full Size Jeep Forum 11 01-29-2009 08:26 AM
Color Question - 1990 Grand Wagoneer thejudge Full Size Jeep Forum 1 01-17-2009 12:34 AM
89 Grand wagoneer engine swap question gimme_fuel Full Size Jeep Forum 13 01-10-2009 12:57 AM
89 grand wagoneer question redxtc Full Size Jeep Forum 2 12-14-2007 07:02 AM
