67 j2000 reverse lights - JeepForum.com
post #1 of 3 Old 03-18-2013, 09:50 AM Thread Starter
jeepsrule1996
1967 J-Series Truck
can anyone tell me if my 67 j2000 came with reverse lights? not sure because it has a custom flatbed on it. i didnt see any plugs or wires coming from the transmission but i just want to double check with you guys.
jeepsrule1996 is offline
post #2 of 3 Old 03-18-2013, 01:53 PM
timgr
1975 CJ6
Which engine/transmission? A '67 should have a T-14 (232) or T-15 (327) or TH400 (either) or T-98 (either) transmission. All but the T-98 can be fitted with a back-up light switch, and you should be able to modify the T-98 shift top to accept a switch. However, I believe the DOT did not require back-up lights until the 1969 model year. The '69 wiring diagram here http://oljeep.com/gw/elec/GW_wiring.html shows them, while the '65-68 diagram does not.
So probably not, if it's really the year you think it is. You could add some lights if you wanted to, either manually controlled, or by adding a switch to your transmission.
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
post #3 of 3 Old 03-18-2013, 02:06 PM Thread Starter
jeepsrule1996
1967 J-Series Truck
I know its a t98. And I was just wondering for inspection purposes. If I don't need them I'm not gonna bother wiring them up right away.
