5.9 cranking slow - JeepForum.com
post #1 of 17 Old 10-27-2009, 10:01 PM Thread Starter
lazyguy
5.9 cranking slow
I just bought these two J Trucks, '75 and a '76, the ;76 has a 360 and TH400 mated to quadra-trac trans case. I hooked up a known good battery cleaned all battery, starter, and solenoid connections but the engine still cranks slow. I know it probably needs all new batt cables and the one to the starter. Is there anything else that could possibly cause this to happen? I was also wondering if anyone has ignition wiring diagrams for these years. I think i have the BID ignition system and can't find a full proof diagram. The haynes manual i picked up covers too many years and is too generic. Does anyone know what color wire is the supposed resistance wire for the coil when running? The reason i don't mention anything about the '75 is that the whole engine side harness got fried and I have yet to put the new harness in, but hopefully when the '76 runs I'll just use it as an example.
lazyguy is offline
post #2 of 17 Old 10-28-2009, 09:18 AM
CSP
Both of those J-trucks would have had the Prestolite ignition system from the factory. There is no resistance wire with this ignition system.
CSP is offline
post #3 of 17 Old 10-28-2009, 10:09 AM Thread Starter
lazyguy
What is the prestolite system because I have only read about the BID, SSI, and points systems on j trucks. and all have some sort of resitor wire.
lazyguy is offline
post #4 of 17 Old 10-28-2009, 12:20 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Clean all connections, replace cables, insure solenoid is operating properly. Might check the starter brushes as well. The Ford style starters are notorious for eating them down, causing slow cranking.
jeepdaddy2000 is offline
post #5 of 17 Old 10-28-2009, 11:15 PM Thread Starter
lazyguy
The current starter is old but new, it was new about a year ago but was never really used and just sat bolted to the engine.
lazyguy is offline
post #6 of 17 Old 10-28-2009, 11:30 PM Thread Starter
lazyguy
here is the truck in question.
lazyguy is offline
post #7 of 17 Old 10-29-2009, 10:53 AM Thread Starter
lazyguy
I have looked at new igniton coils for this year and it says right on the coil, use with an external resitor. I am confused.
lazyguy is offline
post #8 of 17 Old 10-29-2009, 11:04 AM
Pathkiller
1974 CJ5
Will it start and run? Check the timing. Too much timing advance will cause a hard start condition.
Pathkiller is offline
post #9 of 17 Old 10-29-2009, 05:08 PM Thread Starter
lazyguy
Has spark and fuel it just cranks way to slow to ignite and run.
lazyguy is offline
post #10 of 17 Old 10-30-2009, 11:27 AM
CSP
Regardless of what generic, replacement coils say there is no resistor wire with the Prestolite ignition system.
Even if it did, that would have nothing to do with your slow cranking starter.
Saying it has spark and fuel doesn't answer the question about timing. You need to check it.
CSP is offline
post #11 of 17 Old 10-30-2009, 09:26 PM Thread Starter
lazyguy
in the course of trying to get it to turn over faster i removed all the spark plugs from one side and it made a little difference in the crank speed. I will check the timing just to make sure. What is a ballpark timing reading for this engine?
lazyguy is offline
post #12 of 17 Old 11-02-2009, 08:45 AM
CSP
It turned over faster because you removed the element of compression in the cylinders.
CSP is offline
post #13 of 17 Old 11-02-2009, 02:28 PM Thread Starter
lazyguy
Will I get a timing reading even thought is turns so slow?
lazyguy is offline
post #14 of 17 Old 11-09-2009, 11:10 AM
Pathkiller
1974 CJ5
No, but you should be able to set it to TDC and get it to run good enough to use a timing light on.
post #15 of 17 Old 11-10-2009, 01:58 PM Thread Starter
lazyguy
Good news, I ran a dedicated 4ga ground cable from the starter mounting bolt to the battery ground and what a major improvement it made. Now I just have to put the battery ground to the block instead of where the old owner had it, bolted to the A/C bracket. It still didn't start but its getting there.
lazyguy is offline
wipers slow start in cold CARVINSTARVIN Full Size Jeep Forum 0 08-23-2007 10:38 PM
slow wipers on 88 wagoneer redoctober Full Size Jeep Forum 0 03-30-2007 06:02 PM
