4WD vacumn switch - JeepForum.com
post #1 of 6 Old 12-03-2001, 09:05 PM Thread Starter
Bob Minge
4WD vacumn switch
Just bought a '75 J10 pickup. He said the vacumn switch on the dash took it in and out of 4WD. When I got home, tried it on snow and it didn't seem to make a difference. Front wheels always spun. Any help, advice or place to go to get more info???
Bob Minge is offline
post #2 of 6 Old 12-12-2001, 12:10 PM
Hump
Bob, you shouldn't have a vacuum switch on the dash. If you do, someone put it there. For that year J-10 that you have you should either have the Borg-Warner Quadratrac full-time four wheel drive, or the Dana 20 part-time four wheel drive. Only the late model FSJ's had the New Process transfer cases (NP229, NP231,...) that used the vacuum switch.
You probably have the Quadratrac, and that means that you are in four wheel drive all the time. You should probably check and make sure that your drivetrain is stock, or the guy you bought it from might not be being honest with you.
Check out http://www.ifsja.org/ i'm a member there. It follows the same format as here, but it is just for Full Size Jeeps. There are guys there with infinite knowledge about the big Jeeps, and there is never any flaming. The only dumb questions are the ones not asked.
'70 J4800 Buick 350/T18/D20/D44/D60
'90 MJ SWB 4.0L/auto/2wd (4wd conversion in the process)
'98 & '01 XJ Classics both with 3" Skyjacker & BFG AT KOs
Parting '99 & '00 XJ Sports
Hump is offline
post #3 of 6 Old 12-12-2001, 04:39 PM
mud4me
I know for a fact my 1977 J-10 had Quadratrac and it had a vacuum switch in the glove box. Same with my dads older Wagoneer (76 maybe?). Just curious HUMP, is that different than what you're talking about?
As for why your front wheel are spinning, I don't know. Does that mean only the front wheels are driving the truck?
I owned 2 J-10s, 1 Cherokee, and 1 Wagoneer, and never heard of that problem. I have a wild, unexperienced guess that maybe something in the transfer case is broken??
By the way J-10 is neat vehicle! Maybe one day I will restore one.
86 CJ-7, 360, Holley Avenger, T-18, Dana 20, 4" suspension,
mud4me is offline
post #4 of 6 Old 12-18-2001, 12:48 AM
Hump
You're right mud, quadratrac's do have a switch or a button in the glove box for the e-drive. That switch puts the transfer case into part-time four wheel drive from full time four wheel drive. That means that you don't want to drive it anywhere where you don't have slippage, because everything is locked in. That switch it totally different from the dash mounted switch used for New Process transfer cases that take the Jeep from two wheel drive to part time four wheel drive.
As for the front wheels turning all the time, that is just a sign that it has full time 4x4. In other words, it is in four wheel drive all the time. That is how it is supposed to be...all the time. If his transfer case was broken, then he wouldn't be able to go any where. Your transfer case comes off the back of your tranny. The rear driveshaft come of the back of the transfer case, and the front ds out of the front. So if it is broken then nothing turns out of it.
Hump is offline
post #5 of 6 Old 12-18-2001, 02:34 PM
J4GRAND
The QT uses a limited slip-type transfer case to divide the power between f & r. When one set of axles lose traction the QT supplies power to the axle not slipping. As for the vac (or e-drive) switch in the glove box. This allows the driver to lock the f & r together supplying power evenly to the two. It is to be used on slick surfaces only- snow, ice, dirt, mud, etc. An optional low range was also available and can be seen with a lever under the drivers seat on the trans hump or a handle labled low range under the dash.
Patrick V.
Patrick V.
Valparaiso, IN
73 Jeep J4000 360 .040 over, Summit K8600 Cam, Edelbrock Manifold and 750CFM 4V TH400/1339 QT
78 Cherokee Chief- Hunting Property Rig
05 Grand Cherokee- 3.7 V6 5 speed auto
J4GRAND is offline
post #6 of 6 Old 12-19-2001, 12:21 AM Thread Starter
Bob Minge
Thanks for all the help everyone. Now for the next question. It has a single barrel carb and if there is a little hill or a head wind of 10MPH or more I am at 50 MPH. Top speed down hill with a tail wind was 65MPH. Oh, it has the 258??ci in line 6 cyl. Would going to a 2 barrel carb help hold the speed up to 55 or 60 with a wind or over small hills?? I am not looking for top speed but some sort of staying power at road speed. Thanks in advance. Bob
Dose anyone have a mirror switch? todjob2000 Full Size Jeep Forum 0 12-22-2009 05:55 PM
88 sun roof switch .gunslinger. Full Size Jeep Forum 0 10-11-2009 05:14 PM
back up switch rivahrat Full Size Jeep Forum 2 01-31-2006 11:30 PM
switch problem? hemilady Full Size Jeep Forum 1 06-30-2005 11:59 PM
VACCUM SWITCH DIAGRAM? Eduardo Villegas Full Size Jeep Forum 1 01-03-2002 03:27 PM
