4wd swich at the dash.. - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > 4wd swich at the dash..
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 12-07-2001, 04:15 PM   #1
Eduardo Villegas
I have an 87 Grand Wagoneer with a 2wd---4wd switch at the dash also it has a Hi-N-Lo lever close to my seat. The lever is impossible to be mooved. What shall I do?
older jeeps forever
Eduardo Villegas is offline   Reply With Quote Quick reply to this message
Unread 12-15-2001, 10:53 PM   #2
bruno
Eduardo- Hola!
I've got a 1988 WAG that is the same way. The T Case Selector (the lever that get's you to 4-LO is REALLY TOUGH to move. My 4 Wheel guy says that they are all that way, but you can get it there with a lot of muscle or a linkage adjustment.
The 4WD switch on the dash is vaccum operated and you are in 4HI if the light is on. The lever controls 4LO, which unless you are in a very difficult OFF-ROAD situation you shouldn't use.
Hope this helps!
Feliz Navidad!
1997 TJ Sport Custom Moss Green Pearl Coat, w/ARB Lift, Edelbrock IAS, IPF Lights, Tomken Rocker Skids, BFG 31x10.50's on Grizzlys.
bruno is offline   Reply With Quote Quick reply to this message
