401 swap update. HP estimates break in Q's too. - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > 401 swap update. HP estimates break in Q's too.
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 03-28-2013, 01:31 PM   #46
revelc
1985 FSJ Wagoneer
Originally Posted by Eric1080
a muffler shop custom bent mine with 2 1/2" down- straight back and joining both sides together by the transfercase then dynomax 3" muffler to single 3" pipe out. its not mandrel bent but its out of the way and seems to flow well
Sounds cool. Do you have any pictures of this set up?
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline   Reply With Quote Quick reply to this message
Unread 03-28-2013, 01:33 PM   #47
revelc
1985 FSJ Wagoneer
Sounds like a nice set up. Do you have any pictures of where it comes together at the transfer case?
EDIT: Forgive the double post. This iPhone app is quirky.
Unread 03-28-2013, 09:06 PM   #48
revelc
1985 FSJ Wagoneer
Got it started and drove around the parking lot. The tranny felt like it started in high gear.
Don't know how to adjust the 727 linkage.
Can't get the thing to start without giving it gas.
Can't figure out the timing. I'm a diesel tech.
The throttle keeps sticking around 900-1,000 rpm.
I need help. This stuff is Greek compared to all the diesel stuff I've worked on.
Oh and the oil pump has a hellacious leak. Yep, it's a Jeep all right.
Unread 03-29-2013, 04:17 PM   #49
super98lsc
Dont run it with the pump leaking if its bad. Wont deliver the volume you need might hurt it. Wonder if they hosed up the gasket between the filter receiver and pump front cover? Oh yah also check to ensure the oil pressure switches are all installed or holes are plugged off. Set the timing at 15 deg base. Disconnect the vac advance while your doing that and the break-in you can tune the vac advance later. If it stalls below 900-1000 then it sounds like a vac leak someplace or the idle transitions in the carb aren't working/setup correctly. Take both idle mix screws and gently turn them in till they bottom out (gently not to score them) and then back each out 2 full turns. (good starting point) Set idle screw so throttle is cracked about .030 if you look down the blades. At this point as long as the carb is internally good/new and there is not any trash inside it blocking transfer slots in the venturis (just below the throttle blades inside the front venturis) she should idle between 650-800 depending on your cam duration/lift. The idle being out of whack will also cause the start issues.
www.mangierisrc.com
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline   Reply With Quote Quick reply to this message
Unread 03-29-2013, 04:18 PM   #50
super98lsc
Hell if you were close to Austin TX, I would drop by with the wide band datalogger and jet kits. Dial it in would take about 30-45m to get pretty spot on.
www.mangierisrc.com
Unread 03-29-2013, 05:54 PM   #51
revelc
1985 FSJ Wagoneer
I set the timing at 10* for now. Thanks for the tip about the idle screws. Completely forgot about those. It's a brand new carb so no worries there.
The pump is leaking a few drips per minute. It runs around 40 psi when driving and 25 at idle. I can't tell exactly where it's leaking. But it is for sure around the housing. I might throw a Bulltear midplate in and see what happens. I just hope it's quality is better than the dipstick that I got from them.
I still don't know if I should use intake runners and valley pan together to fix the coolant leak.
Got the transmission shift linkage, and throttle valves dialed in.
Unread 03-31-2013, 09:21 AM   #52
CSP
Don't drive it without adjusting the throttle modulator for the transmission first. You'll burn up the trans quickly. Google can get you to a webpage on how to adjust it. I know I've seen one on www.ifsja.org .
CSP is offline   Reply With Quote Quick reply to this message
Unread 03-31-2013, 10:12 AM   #53
revelc
1985 FSJ Wagoneer
I already got it dialed in. Shifts great and holds gears like I like it.
Unread 03-31-2013, 10:16 AM   #54
Saul32
1988 FSJ Wagoneer
Good stuff. Did you get the leak fixed yet?
Nothing important...
Saul32 is offline   Reply With Quote Quick reply to this message
Unread 03-31-2013, 11:36 AM   #55
revelc
1985 FSJ Wagoneer
Hope so. I took my sweet time on the valley pan and didn't force anything this time. Cleaned it all up really well and used high temp rtv strategically. I'm letting it sit two days before I put the coolant back in and run it. Hopefully it helps it seal up well.
Now I just have to get the oil leak figured out. It's not horrible, but its dripping enough to be annoying. It seems to be coming from the oil pump. I am worried I might have screwed it up trying to prime my pump without petroleum jelly in there. I just spun a drill on high with the old dizzy for about a minute before it started pumping.
Unread 03-31-2013, 11:23 PM   #56
jeepdj5
1982 FSJ Cherokee
Return the pump and get a new one?
Sent from my fsj Cherokee chief using JeepForum
jeepdj5 is offline   Reply With Quote Quick reply to this message
Unread 03-31-2013, 11:33 PM   #57
revelc
1985 FSJ Wagoneer
It's an AMC motor. The pump is a part of the timing cover...
Unread 04-01-2013, 12:18 AM   #58
jeepdj5
1982 FSJ Cherokee
I know that!! I thought it was replaced during the build? Probably still a warranty??? Pretty goofy system if you ask me, my chief has the 258 so I have nothing to worry about
Unread 04-01-2013, 12:28 AM   #59
revelc
1985 FSJ Wagoneer
The gears were replaced. The pump is original. I am not sure if its leaking from the idler shaft, the gasket, or somewhere that I can't see without taking my alternator off.
All you have to worry about is keeping up on the interstate lol.
Unread 04-01-2013, 07:22 AM   #60
Eric1080
1978 J-Series Truck
mine leaked until i put in a midplate for the pump when i noticed a bad gasket. i added this midplate and my oil pressure went up a fair amount: http://www.bjsoffroad.com/prod-605.htm
Eric1080 is offline   Reply With Quote Quick reply to this message
