401 swap update. HP estimates break in Q's too. - Page 3 - JeepForum.com
post #31 of 85 Old 03-24-2013, 10:37 PM
Eric1080
1978 J-Series Truck
i like how the engine builder specified high zinc oil multiple times. perhaps i should change my oil...... if its lasted for 30k since the rebuild with rotella then it should be fine. op- your setup on your 401 is very similar to mine. ive used 87 octane when $$$ was short with no pinging.
Eric1080 is offline
post #32 of 85 Old 03-24-2013, 10:55 PM Thread Starter
revelc
1985 FSJ Wagoneer
I am one to take as many precautions because I am hard on my equipment. I'll use additives.
Glad to hear I might be able to use low grade fuel in a pinch.
How do you like your set up on the road, passing, merging?
Ever mess with any Hondas or young punks around town?
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #33 of 85 Old 03-25-2013, 08:01 PM
Eric1080
1978 J-Series Truck
with 4.10s and 35s it was excellent in NY where the elevation was 1500 feet. here in CO i live at 9k and lost a lot of power. i might switch to 33s so i can get it back. it will still move though. i raced a civic (one of those gay ones that was "Upgraded" and beat him to the top with a full load of firewood. he looked suprised
Eric1080 is offline
post #34 of 85 Old 03-25-2013, 08:01 PM
Eric1080
1978 J-Series Truck
u using manifolds or headers?
Eric1080 is offline
post #35 of 85 Old 03-25-2013, 08:04 PM Thread Starter
revelc
1985 FSJ Wagoneer
Manifolds.
revelc is offline
post #36 of 85 Old 03-25-2013, 08:06 PM Thread Starter
revelc
1985 FSJ Wagoneer
I want a few minor victories like that. And something that might surprise some of the old guys with Hot Rods where I'm from.
revelc is offline
post #37 of 85 Old 03-27-2013, 07:45 PM
28uptwo
I was running 425 Hp with a 401. We had to do a lot of head work on the stock heads. I had the same build that you have but, Holley 750 double pumper, Torker II intake, 510 lift on cam and headers. I was into mud racing at the time. I could run 7100 RPMs for about 2 mins before it would start to get warm. I ran the motor for over 5 years in the races then put it in a 71 Javalin. drove it for 2 years and sold it. I wish I had another one. Fun motors.
28uptwo is offline
post #38 of 85 Old 03-27-2013, 08:48 PM
Saul32
1988 FSJ Wagoneer
with your stock manifolds, did you port em at the bend or do u keep em completely stock?
Nothing important...
Saul32 is offline
post #39 of 85 Old 03-27-2013, 09:01 PM Thread Starter
revelc
1985 FSJ Wagoneer
The heads only had a 5-angle valve job with mild porting. I don't know if the valves were replaced with bigger ones or what else was done with them.
Your engine sounded like a beast. 7,100 rpm is supposed to be murder for the 401's. I'm starting to think about adding a mild shot of nitrous to achieve those kind of numbers without having to tear into it again.
Nope those things are stock. Plugged air tubes and all. I have wanted to throw headers on but people seem to steer me away from them unless I can afford $600 Doug Thornleys.
I am about to have a new exhaust made from the y-pipe back and still can't decide how to go about that.
revelc is offline
post #40 of 85 Old 03-27-2013, 09:08 PM
Saul32
1988 FSJ Wagoneer
Yeah I was also thinking of doing the Thorleys but that price yikes!!
I read a thread somewhere and somebody mentioned getting better performance out of the stock manifolds by porting em at one of the bends. I'll see if I can find it and send you the link.
Saul32 is offline
post #41 of 85 Old 03-27-2013, 09:33 PM Thread Starter
revelc
1985 FSJ Wagoneer
That would be appreciated.
revelc is offline
post #42 of 85 Old 03-27-2013, 09:48 PM
Saul32
1988 FSJ Wagoneer
"The only headers that still use the factory y-pipe were the Edelbrock, and they have been discontinued. IMO the use of the stock y-pipe negates the flow of any headers, the y-pipe is the bottle neck even in the stock system. You would be better off porting the first bend in the stock manifolds and open up after the y-pipe to a 2-1/2" exhaust."
RockRollin
Saul32 is offline
post #43 of 85 Old 03-27-2013, 09:51 PM
Saul32
1988 FSJ Wagoneer
Seems like its worth a try.. save yourself $600.
What would you use to do it tho?
Saul32 is offline
post #44 of 85 Old 03-27-2013, 10:29 PM Thread Starter
revelc
1985 FSJ Wagoneer
Well I don't know what he means by "The first bend"
But using an air grinder with a carbide bit will make short work of anything.
revelc is offline
post #45 of 85 Old 03-28-2013, 09:52 AM
Eric1080
1978 J-Series Truck
a muffler shop custom bent mine with 2 1/2" down- straight back and joining both sides together by the transfercase then dynomax 3" muffler to single 3" pipe out. its not mandrel bent but its out of the way and seems to flow well
Eric1080 is offline
