360 Air Injection System - JeepForum.com
post #1 of 5 Old 05-04-2007, 11:21 AM Thread Starter
kmjbpkohler
Can anyone give me the pros and cons on removing all of the air injection systems on my engine. I know the emissions side of it. I should'nt have to worry about inspections. The main thing I need to know is if this will harm the engine overtime and what is involved with removal, i.e. plugging up all the holes and such.
Jeeps are alot like houseboats
kmjbpkohler is offline
post #2 of 5 Old 05-04-2007, 08:11 PM
jeepfan93
1991 FSJ Wagoneer
First thing you'll have to do is go to the hardware store and get plugs for the AIR holes in the exhaust manifolds. Then remove the belt for the pump and the pump itself. There will be a metal line going to the cat from the diverter valve. You will need to cut and plug it at the cat to have a clean look. Of course rearrange the vac lines after your done. It will not have any long term affects on the engine. But you probably won't see any increase in power since it is just pumping air into the exhaust.
jeepfan93 is offline
post #3 of 5 Old 05-17-2007, 10:48 AM
carnuck
1984 J-Series Truck
If the pump is near death from seizing, you will notice a major power increase by removing it, BUT the original cat needs to be removed or gutted so your floor doesn't catch on fire from the heat it will start to produce (I saw one dripping molten metal on the road!)
If you want to be environmentally friendly, replace the old cat with a high flow non-aerobic one (Random technologies makes one that is 50 state legal) and the AIR stuff can go in the trash bin (you will actually produce less emissions than the original cat did from the factory and in most cases use less fuel) The EGR valve is needed to keep your motor from pinging itself to death.
carnuck is offline
post #4 of 5 Old 05-18-2007, 04:04 PM Thread Starter
kmjbpkohler
Thanks guys, I've taken off the air pump, exhaust tubes, plugged the holes, rerouted the vacuum lines, changed exhaust manifold gaskets, retapped the 2 bolts that broke, put everything back together and could not believe the amount of room there is now and the performance seems better. Also sounds pretty tuff with the true duals and flowmasters.
Jeeps might not be as bad as houseboats
post #5 of 5 Old 05-18-2007, 09:20 PM
carnuck
1984 J-Series Truck
BOAT = bring over another thousand! Did the cats go bye bye too?
carnuck is offline
pics of your wagoneer exhaust system with headers?? blownmope Full Size Jeep Forum 1 11-18-2009 08:30 AM
79 wagoneer start system wiring schematic blownmope Full Size Jeep Forum 2 11-15-2009 10:09 AM
serpentine belt system Scott00TJ Full Size Jeep Forum 1 08-06-2009 02:18 PM
emisions system and a 1406 edel brock help me a2d3a2m6 Full Size Jeep Forum 1 05-31-2008 06:20 PM
Fuel Injection on GW's lasarus Full Size Jeep Forum 11 06-30-2002 10:09 PM
