327 Vigiliante water pump options? - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > 327 Vigiliante water pump options?
Stainless Steel Door Hinge PinsPoly Door Hinge BushingsSteinjager TJ tube doors
Unread 08-16-2014, 09:45 PM   #1
strvger01
1966 CJ5
well, my 1966 wagoneer, 327 vigilante, is leaking at the water pump. all the local parts places only have a "remove and rebuild" option. yep, i have to pull it, give it to them to send out for rebuild somewhere on the east coast, and wait to get it back. of course i have to pay for shipping both ways in addition to the rebuild cost, and no guarantee as to how long it will take.
a couple of online parts stores have one listed but it is the same one as for the sbc engines. i didn't think they would be the same, but maybe someone here can shed some light on that. they list this one: GMB 130-1350P for both the sbc and amc 327.
does anyone have a source for a new, rebuilt, or good used water pump specific for my waggy? i'll be posting here in the classifieds for one, but thought i'd just ask here.
thanks.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline   Reply With Quote
Unread 08-16-2014, 10:08 PM   #2
DotJumper
Junior Member
1988 FSJ Wagoneer
Isn't the Viligant a GM Buick block that Willys bought tooling from GM for? And if GMB is for GM Buick, then that pump might be a fit.
DotJumper is offline   Reply With Quote
Unread 08-16-2014, 11:00 PM   #3
CSP
No the Chevy pump is not the same and no, it isn't a Buick block.
CSP is offline   Reply With Quote
Unread 08-17-2014, 03:43 PM   #4
strvger01
1966 CJ5
thanks CSP. i knew i couldn't get that lucky!
the search continues...
Unread 08-24-2014, 12:52 PM   #5
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Might try this...
http://www.summitracing.com/parts/aaz-58-275/overview/
http://www.americanpartsdepot.com/Co...temGrille2.htm
Most water pumps use standard bearings and seals. If all else fails, you can press the hub off and disassemnble the pump. Many times unless the shaft is bad, you can replace the bearings and seals and re-assemble yourself.
jeepdaddy2000 is offline   Reply With Quote
Unread 08-25-2014, 08:45 AM   #6
strvger01
1966 CJ5
ok jeepdaddy. i'll consider that once i get it off and look it over real good. been having some rough weather here and as it is outside, it's been delayed. should be good this week, so i should get it off at least.
Unread 08-26-2014, 04:30 PM   #7
jaketr1
That's engine is why I didn't buy a 67 j truck that was in good shape bc to hard to find parts for that 327
LOOKING for a j truck or comanche $3500,KS,MO,OK area
99 TJ- daily driver
jaketr1 is offline   Reply With Quote
