229 transfer case - JeepForum.com
post #1 of 3 Old 06-24-2013, 09:45 AM Thread Starter
SmokeyLives
1989 FSJ Wagoneer
229 transfer case
Hey all!
I have a 1989 Grand Wagoneer that had its transmission destroyed by a tow truck driver. It sat for years, but I've replaced the 727 with a rebuilt one and have the engine running nicely, but the beast won't engage in any gear. Will the 229 transfer case function at all with the viscous coupler trashed?
any other ideas?
SmokeyLives is offline
post #2 of 3 Old 06-24-2013, 10:08 PM
olliehopnoodle
1982 FSJ Cherokee
The 229 has a 2wd mode, that should get you moving. If you can get it into 4 low the VC is not used. Do you get anything when you switch gears? Does the engine slow down at all?
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #3 of 3 Old 06-26-2013, 04:20 PM
super98lsc
Like Ollie said you want to check the vacuum actuation on the T_Case make certain its going into 2wd and not stuck in 4 high.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
