1990 wagoneer - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > 1990 wagoneer
Gibson WK HEMI 3" Catback - 5 Day Special!The ULTIMATE "Selectable" Locker System! Brough**Flash Weekend Sale** Rockridge4wd.com Only!
Unread 02-21-2015, 08:02 PM   #1
10dwenger
1990 wagoneer
I'm buying a clean '90 wagon after I totalled/sold my '05 wrangler (first jeep, my baby). A few questions for you all. What problems too look for, what are the common maintenance issues, what to replace, and what is the first thing you did to it. Any help is welcomed.
10dwenger is offline   Reply With Quote Quick reply to this message
Unread 02-21-2015, 08:37 PM   #2
RockRollin
RockRollin's Avatar
1990 FSJ Wagoneer
Full fluid flush FIRST THING.
There are many things that you can upgrade, but its probably best to drive it a bit and see where things are at. Do all windows work, what kind of mileage is it getting. It will let you know what it need after a few days.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline   Reply With Quote Quick reply to this message
Unread 02-22-2015, 02:42 AM   #3
owntmeal4life
owntmeal4life's Avatar
1980 FSJ Wagoneer
I'd fix any issues clean up check for rust underbody by gas tank area were rust can get out of hand
owntmeal4life is offline   Reply With Quote Quick reply to this message
Unread 08-07-2015, 09:34 PM   #4
Harbison
1990 FSJ Wagoneer
10dwenger, give us an update. I owned my 90 GW for 10 years and drove it 50K.
Harbison is offline   Reply With Quote Quick reply to this message
Unread 08-11-2015, 10:22 AM   #5
twmattox
Like mentioned above, check for rust around the fuel tank skid. A couple other areas to look for rust are under the carpet by the rear doors, under the carpet by the front seats (moisture here also corrodes a couple wire connections). This rust is generally caused either by leaking windshield gasket (if you are lucky the frame isn't rusty) or by clogged floor vents (leaves etc can clog them). Leaves can enter the grille on top and clog the vent drains as well as the heater core.
Mechanically, keep an eye on the timing chain cover. They are aluminum and can crack/corrode.
Outside of these things, just remember it is a 20+ year old rig and needs TLC...
twmattox is offline   Reply With Quote Quick reply to this message
