1990 Wagoneer - Page 2 - JeepForum.com
post #16 of 23 Old 06-24-2013, 10:44 AM Thread Starter
7179CJ5
1979 CJ5
Great information, so the 1990 is not all wheel drive? And there is absolutely no need to take off the front drive shaft. What about gas Mileage? He said 14 miles to the gallon, 360 v8 is a big engine, anybody have an avg gas mileage on it?
7179CJ5 is offline
post #17 of 23 Old 06-24-2013, 11:32 AM
super98lsc
Mine is nearly stock 1 rebuild .030 over, not certain what was done internally by the previous owner. It is very well tuned by me using a wideband 02, has electric fan, HEI ignition with MSD coil, Single exhaust no cats and all the smog BS removed. I get 13.6 on the highway <70mph. If it is getting 14 that is likely the best it will ever get. Aside from an overdrive swap, fuel injection, and performing other things to reduce wind resistance. Mine is on a 4" lift and 31x10.50's with tow package 3.31 gears. Check under it you can read the tag on the T-Case and verify its an NP229 case. All the 90's I knew of were 229 equipped. It should have the 2wd/4wd slider switch at the bottom of the dash on the right side of the steering column. Then a high/N/Low flag shifter under the driver seat against the trans tunnel.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #18 of 23 Old 06-24-2013, 11:55 AM Thread Starter
7179CJ5
1979 CJ5
Yes it has all that you described. Well I guess I'll have to ask him to put that driveshaft back on so I can test the 4wd. Other than that everything else looks pretty good.
7179CJ5 is offline
post #19 of 23 Old 06-24-2013, 12:13 PM
Little Green
1991 FSJ Wagoneer
Truck looks good for 3K. You can find a good used front seat. There is some trim missing from the rear passenger door panel that I can see. Mileage isn't a huge concern if it's been taken care of and 14 MPG is really good. I get about 9 in the city and 13 on the highway at 65.
91 Grand Wagoneer(Winter vehicle/project)
Prior 08 Wrangler JK Lifted-Miss her
Little Green is offline
post #20 of 23 Old 06-24-2013, 06:27 PM
olliehopnoodle
1982 FSJ Cherokee
Yes, have him put the drive shaft back on. His reason for removing it doesn't make sense. The 229 has a 2wd mode. But a lot of people bought into this.
Also, read this:
http://www.ifsja.org/tech/tcase/selectrac.html
It explains how to operate the transfer case. You will want to check both 4 hi and 4 low.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #21 of 23 Old 06-24-2013, 07:49 PM Thread Starter
7179CJ5
1979 CJ5
Cool, thank you
7179CJ5 is offline
post #22 of 23 Old 06-24-2013, 09:16 PM
olliehopnoodle
1982 FSJ Cherokee
No problem. 4lo on pavement is okay but keep it in a straight line.
post #23 of 23 Old 06-26-2013, 08:13 PM Thread Starter
7179CJ5
1979 CJ5
Well want to thank everybody for replying toy post and giving me some really good information to use when considering the purchase of a '90 Grand Wagoneer. Everything considered I think I'll pass on this one. Once again thank you for your replies.
7179CJ5 is offline
