1988 Jeep wont start - JeepForum.com
post #1 of 9 Old 04-27-2009, 02:17 AM Thread Starter
jeepster60
1988 XJ Cherokee
Help..tried to start my Jeep..it cranks up, lights work,fuel pump goes on, but it wont start. It cranks up great..had battery checked, its fine..getting spark from spark plugs..nothing from coil..how do I know if its my coil or ignition module?..its my only transportation and I need answers quick.
jeepster60 is offline
post #2 of 9 Old 04-27-2009, 04:31 AM
thejon2524
What motor is in it?
thejon2524 is offline
post #3 of 9 Old 04-27-2009, 09:56 AM
BJ's Off-Road
1979 FSJ Cherokee
All it should need to run is fuel, air and spark. If you are getting spark at your spark plugs, I wouldn't think it would be the coil or the module because I believe if either go out, you don't get any spark at all.
You say the fuel pump goes on (must be an electric fuel pump?)... Are you getting fuel at the intake? Just because it is making noise doesn't mean that it is working.
www.bjsoffroad.com
BJ's Off-Road is offline
post #4 of 9 Old 04-27-2009, 08:39 PM Thread Starter
jeepster60
1988 XJ Cherokee
hmmm I'll have to check on that..Ill let you know..thanks
post #5 of 9 Old 04-27-2009, 09:31 PM Thread Starter
jeepster60
1988 XJ Cherokee
If Im correct its a 252..
post #6 of 9 Old 04-28-2009, 10:04 AM
BJ's Off-Road
1979 FSJ Cherokee
What kind of a vehicle?
www.bjsoffroad.com
post #7 of 9 Old 04-28-2009, 01:30 PM Thread Starter
jeepster60
1988 XJ Cherokee
1988 Jeep Cherokee Laredo 4 wheel drive..6 cyl
post #8 of 9 Old 04-28-2009, 02:14 PM
BJ's Off-Road
1979 FSJ Cherokee
You might want to post this in the XJ forum since the full-size Cherokees were only built from 1974-1983. You might get some more educated responses...
www.bjsoffroad.com
post #9 of 9 Old 04-30-2009, 11:59 AM
carnuck
1984 J-Series Truck
If there is no spark from the coil, the plugs aren't getting anything. 9 out of 10 times it's a crank position sensor. (top of the bell housing on driver's side) It's either dead, wires corroded or melted to the exhaust manifold (because someone did work and didn't put it back where it's supposed to be)
carnuck is offline
New motor keeps backfiring and wont start cmschule Full Size Jeep Forum 9 08-27-2009 11:40 AM
1988 Grand Wagonner suddenly wont idle kevcave Full Size Jeep Forum 1 02-09-2009 08:45 AM
1988 Jeep Grand wagoneer run-on surfdad Full Size Jeep Forum 2 08-11-2006 03:10 PM
1988 jeep J10, it's rare eh? ktmracer419 Full Size Jeep Forum 5 10-11-2005 01:05 PM
My 1988 Jeep Comanche laufee Full Size Jeep Forum 2 06-21-2004 11:36 AM
