1988 Jeep Grand Wagoneer starting problem - JeepForum.com
post #1 of 18 Old 03-25-2012, 10:25 AM Thread Starter
danieltladd
1988 J-Series Truck
Hey guys new to the forum here and I really like what I'm seeing. I recently bought my first Jeep and I bought a wagoneer, mainly because I love the lines and the fact that I grew up riding in my dad's wagoneer and that whole feeling has never left me. The issue I'm having with mine is that it was upgraded after the engine was rebuilt with the edelbrock performed intake, and carb. I'm not so sure about the heads. I replaced the mechanical fuel pump and it still starts like crap. I set the timing adjusted the carb and it doesn't seem to get fuel at all when starting. If i turn it off and fire it up immediately it starts right up. What can I do to fix this?
Thanks, Dan
danieltladd is offline
post #2 of 18 Old 03-26-2012, 12:29 PM
pleontks
1976 J-Series Truck
if you just barely crack the fuel line where it goes in to the carb, and have someone turn the key while you look, the gas should spray everywhere. If it just dribbles a little, your fuel pump is not working. It should spray like crazy.
I've found in the older cars, that the lobe on the camshaft that pumps the mechanical fuel pump wears down and doesn't pump enough fuel for the engine. Now I run elec fuel pumps on all my stuff. That may be the answer for you.
Beauty is in the eye of the jeepowner.
pleontks is offline
post #3 of 18 Old 03-27-2012, 02:21 PM
Dumpy
1972 J-Series Truck
needle and seat could be stuck closed, too. Post on IFSJA.org. you should get plenty of replies
Dumpy is offline
post #4 of 18 Old 04-09-2012, 09:00 PM
carnuck
1984 J-Series Truck
Could it be the third line on the fuel filter isn't in the 12:00 position?
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #5 of 18 Old 04-11-2012, 07:59 PM
pleontks
1976 J-Series Truck
what's up with the useless posts of 'go to a different forum'?
pleontks is offline
post #6 of 18 Old 04-12-2012, 10:08 AM Thread Starter
danieltladd
1988 J-Series Truck
Actually the third line is in the the three o clock position what affect does this have?
post #7 of 18 Old 04-12-2012, 06:26 PM
pleontks
1976 J-Series Truck
needs to be at 12 o'clock, otherwise all the fuel goes out that line back to the tank
pleontks is offline
post #8 of 18 Old 04-13-2012, 06:52 AM Thread Starter
danieltladd
1988 J-Series Truck
12 o clock towards the front or back of the vehicle
post #9 of 18 Old 04-13-2012, 10:44 AM
pleontks
1976 J-Series Truck
pointing towards the carb, I believe
it kinda acts like a regulator on the fuel. Instead of trying to push the extra gas into carb, it allows it to go back to tank
pleontks is offline
post #10 of 18 Old 04-16-2012, 10:17 AM Thread Starter
danieltladd
1988 J-Series Truck
Ok, I have done all of the above and I believe I've figured out what the problem is but I do not the proper resolution. Gas seems to be boiling inside of the Carb. I'm not sure how to remedy this I was told use a spacer but I'm not sure if something else could be the issue.
Thanks, Dan
post #11 of 18 Old 04-17-2012, 09:25 PM
megajeep
1989 FSJ Wagoneer
I got a insulating space with my carb rebuild kit. When I removed my emission stuff I left the vent tube open and the fuel would evaporate away in a couple of days. I just plugged it with some RTV and that stopped that. It could also be emptying through the power enrichment valve.
My final solution was to replace my mechanical pump with an electric.
megajeep is offline
post #12 of 18 Old 04-17-2012, 09:29 PM
megajeep
1989 FSJ Wagoneer
BTW 12 o'clock mean 12 o'clock high or on top. Make sure the return line is above the line going into the carb.
megajeep is offline
post #13 of 18 Old 04-18-2012, 11:09 AM
CutterN55
If the prob is still present after clocking the filter correctly & you have good fuel press, then do the phenolic spacer. I was having probs with fuel boiling in the bowl leading to lots of cranking before finally firing off as well. Remember not to tighten down the carb too much though, or you will crack the spacer. Tighten it a little at a time in a star pattern like you would anything else.
Semper Fi!
86 CJ7 258/Np435/D300/Waggy D44's
CutterN55 is offline
post #14 of 18 Old 04-18-2012, 08:05 PM
pleontks
1976 J-Series Truck
also make sure fuel line is not too close to exhaust and heating up there
pleontks is offline
post #15 of 18 Old 04-20-2012, 09:00 AM Thread Starter
danieltladd
1988 J-Series Truck
Update: Ok I've installed a 1/2" phenolic spacer and routed the fuel filter so that the return line is higher than line going into the carb. The starting has gotten significantly better however it's not perfect. After about an hour the gas seems to evaporate and I have to crank for a bit to get it to go. Summer is approaching and being in Florida I only see it getting worse I still think I have a heat transfer issue any other ideas?
1988 Jeep Grand Wagoneer Restarting Problems banderson98271 Full Size Jeep Forum 2 04-30-2008 12:59 PM
1988 Grand Wagoneer Electrical Problem jnc123ny Full Size Jeep Forum 3 04-01-2008 12:55 AM
1988 Jeep Grand wagoneer run-on surfdad Full Size Jeep Forum 2 08-11-2006 03:10 PM
1988 Grand Wagoneer RBlatch Full Size Jeep Forum 1 02-28-2005 10:57 AM
1988 Grand Wagoneer carb problem? skitownusa Full Size Jeep Forum 0 12-13-2004 09:38 AM
