1988 Grand Wagoneer... how's the motor? - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > 1988 Grand Wagoneer... how's the motor?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 10-28-2006, 09:34 AM   #1
scrible
1981 CJ5
I found a good condition 1988 Grand Wagoneer with the AMC 360 for $500. What was the power output for the 360 this year? I am planning on swapping it into my 81 cj-5 if I get it. Is this motor worth the trouble? Low mileage, very clean. I just wondered if the motor was very powerful. Anything is better than my 258 though right?
scrible is offline   Reply With Quote Quick reply to this message
Unread 10-29-2006, 03:47 PM   #2
scrible
1981 CJ5
Ended up getting it for $450. What are the specs for this motor? I can't find anything specific for this model year.
Unread 10-30-2006, 10:18 AM   #3
bharris68
If I recall correctly - the power output on that motor varied depending on whether or not it was equipped with a 4bbl or 2bbl carb.
bharris68 is offline   Reply With Quote Quick reply to this message
Unread 10-30-2006, 03:09 PM   #4
scrible
1981 CJ5
well it is a 2bbl but I am replacing it with an edelbrock performer intake and a 4 barrel carb
Unread 10-31-2006, 07:44 AM   #5
J4GRAND
The HP numbers for the later 360s were low because of emissions equipment, but with a 4bbl mani/carb and a mild cam, you can get 250-275 hp out of them easily. I built a 360 for my 73 J4000 and it was desktop-dynoed at almost 350hp.
Patrick V.
Valparaiso, IN
73 Jeep J4000 360 .040 over, Summit K8600 Cam, Edelbrock Manifold and 750CFM 4V TH400/1339 QT
78 Cherokee Chief- Hunting Property Rig
05 Grand Cherokee- 3.7 V6 5 speed auto
J4GRAND is offline   Reply With Quote Quick reply to this message
Unread 11-02-2006, 02:07 PM   #6
JayJEEPguy
Stock hp for the later GWs was around 144hp and nearly 250ft-lbs of torque.
Lots of GRUNT.
Jason T.
'99 GMC Suburban: Gas-guzzling people mover with 18" Z71 wheels
'04 WJ:Special Edition. V8, QTII, 2"BB, Bilsteins & 245/75/16" Goodyears
'02 WJ:4.7L, Selec-Trac. Totalled 9-12-07. Click to hearKolak 3" exhaust sound clip
http://www.cardomain.com/id/MourningWoody
JayJEEPguy is offline   Reply With Quote Quick reply to this message
Unread 11-03-2006, 09:19 AM   #7
Calbob
You wont pass any gas stations, as I am learing.
Calbob is offline   Reply With Quote Quick reply to this message
Unread 11-03-2006, 08:01 PM   #8
JOKER4INK
I took an 88 Wagoneer 360 and put it in my 88 YJ. I love the 360! Great torque, runs like a top, easy as hell to work on! I went with an HEI ignition to simplify wiring and it starts practically instantly. I still have the stock Motorcraft 2bbl on it but it runs great so Im not fooling wtih it. I think a 360 in your CJ is a great idea. I think you will be pleased with the result.
88 YJ...kinda. Clayton Hard Arms, V8, 1 tons running gear, twin sticked, Irok's, fuel cell, multi-colored
JOKER4INK is offline   Reply With Quote Quick reply to this message
