1984 wagoneer,starting problem - JeepForum.com
post #1 of 1 Old 04-12-2010, 01:38 PM Thread Starter
gasser66
1984 FSJ Wagoneer
I have a 1984 grand wagoneer.I have replaced starter , regulator, battery.But if I let it sit it will not start without a jump.I also have to lift up on the shift lever so it will start.I also have replaced neutral safety switch.This has happened so many times.Each time I have to check the starter then the regulator and the battery.They are usually in working condition.Is there anyone else with a demon in their wiring or somthing similar?
gasser66 is offline
PM Box Problem Tshark299 JeepForum Announcements 11 05-03-2009 06:06 AM
I need helpabout starting a group TJ Flexer JeepForum Announcements 2 05-11-2008 04:09 PM
anyone else having this problem? MissMurder JeepForum Announcements 4 01-16-2008 11:10 AM
Have you guys ever thought of starting a... smunns JeepForum Announcements 3 05-09-2002 09:13 PM
Having problem with PMs kegmaster JeepForum Announcements 1 03-14-2002 03:26 PM
