1982 Wagoneer Gas Tank - JeepForum.com
post #1 of 4 Old 11-20-2011, 11:44 AM Thread Starter
sawyerg
1982 FSJ Wagoneer
Hi there,
I have a 1982 Wagoneer and the gas gauge does not work at this time. I have plans to replace fuel pump, sending unit ect... in the near future but for now I was wondering if anybody know how many gallons the stock tank holds? Thanks!
sawyerg is offline
post #2 of 4 Old 11-20-2011, 06:54 PM
robert_hollis
I know my 79 holds 21 gallons, so you may be around there. I think they changed tank designs in 80, so no promises...
You read it. You can't unread it!
1978 Cherokee Chief - bought for parts, and sold as a runner
robert_hollis is offline
post #3 of 4 Old 11-20-2011, 06:56 PM
austinaubinoe
my 91 holds 21 as well.
austinaubinoe is offline
post #4 of 4 Old 11-22-2011, 07:54 PM
carnuck
1984 J-Series Truck
Fuel pump is on the motor, not in the tank. There is an access panel under the back set on driver's side you can check the ground wire isn't broken off.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
1982 , capacity , gas , tank , wagoneer
1982 Wagoneer Limited - heat/defrost issue chrisplaner Full Size Jeep Forum 6 02-01-2012 05:28 PM
1982 FSJ Wagoneer keeps slipping into neutral when driving briancobabe Full Size Jeep Forum 0 11-30-2010 03:43 PM
Grand wagoneer fuel tank Eric_B_1984 Full Size Jeep Forum 9 11-17-2010 02:00 PM
new tank for '70 wagoneer waynews2u Full Size Jeep Forum 12 02-20-2010 11:04 PM
New Member - Should I Get 1982 Wagoneer IdahoMark Full Size Jeep Forum 5 12-18-2008 08:44 PM
