1980 Sj 4lo - JeepForum.com
post #1 of 6 Old 01-08-2011, 08:39 PM Thread Starter
Skittlesquad
1995 XJ Cherokee
1980 Sj 4lo
Hi i just git a 1980 Sj and am trying to figure out how to put it in 4 lo, its nothing like my cherokee, i lock the hub put the selector in 4hi and its fine but if i try to put it in low the lever and light says its in 4lo but it make that high pitch grinding/whining noise like its not lined up. what am i doing wrong or not doing
Skittlesquad is offline
post #2 of 6 Old 01-09-2011, 02:17 PM
jeepdavetj
1991 XJ Cherokee
The linkage may be bent, or out of wack a lil. You may have to push it down a lil more than you are. Or get under it and see if the bushings or rods are out of wack. I had the same issue on my old Grand Waggy. I messed with it till I got it right.
I don't blame people for their mistakes, but I do expect they pay for them.
Ash from Army of Darkness
Alright you Primitive Screwheads, listen up! You see this? This... is my boomstick! The twelve-gauge double-barreled Remington. S-Mart's top of the line. You can find this in the sporting goods department. That's right, this sweet baby was made in Grand Rapids, Michigan. Retails for about a hundred and nine, ninety five. It's got a walnut stock, cobalt blue steel, and a hair trigger. That's right. Shop smart. Shop S-Mart. You got that?
jeepdavetj is offline
post #3 of 6 Old 01-10-2011, 07:05 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Chances are good that there is a reverse neutral lock. I'm not sure when they did away with that feature, but I have it on my 73.
I need to shift into reverse, then into neutral, and then the lever goes right into 4lo. Same to get it out. You need to fiddle with it shifting from P to R to N ot from N to R to N to try and get it to shift in.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #4 of 6 Old 01-17-2011, 01:30 AM
carnuck
1984 J-Series Truck
I had to shut mine off, shift into low then start up again. That was when my high forward clutches were just about dead and fried together.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #5 of 6 Old 01-18-2011, 03:48 PM Thread Starter
Skittlesquad
1995 XJ Cherokee
iv tried all those things and still nothing, like it wont go all the way in , is there shift forks or somthing inside that might be bent?
post #6 of 6 Old 01-18-2011, 07:59 PM
carnuck
1984 J-Series Truck
That or the linkage may not be pushing it all the way.
FOR SALE STUFF
carnuck is offline
FSM on CD for 1980 Wagoneer Nikonised Full Size Jeep Forum 4 12-22-2009 08:18 PM
Picked up a 1980 J-10... Boomhauer Full Size Jeep Forum 0 08-14-2009 12:46 PM
1980, J20 Value Question... mknherhappy Full Size Jeep Forum 1 05-11-2009 11:18 AM
1980 j10 for $100 lonestar_yj Full Size Jeep Forum 0 05-06-2009 09:37 AM
1980 4.2l kernalklink Full Size Jeep Forum 3 01-02-2007 02:46 PM
