1980 CHEROKEE FULL TIME 4WD - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > 1980 CHEROKEE FULL TIME 4WD
Oconeeoffroad.com Blowing out inventory at special pricesRubicon express discounts from oconee off-roadGreat prices on seating!--Oconee Off-Road
Unread 06-23-2002, 09:56 PM   #1
im5811mp
I AM GOING TO PURCHASE A 1980 CHEROKEE WITH FULL TIME 4WD. I WAS WONDERING IF IT WAS POSSIBLE TO CONVERT THE FRONT AXLE TO MANUAL HUBS? I THINK IT HAS A DANA 44 FRONT AXLE, I'M UNSURE OF THE REAR AXLE. ALSO IT HAS A 360 V-8, WILL ANY CHRYSLER 360 SWAP IN OR DOES IT HAVE TO COME FROM A JEEP? ANY INFO WOULD BE GREATLY APPRECIATED.
im5811mp is offline   Reply With Quote
Unread 06-23-2002, 11:42 PM   #2
Bob Barry
You can't convert to manual hubs with your transfer case; there is no mode in which the front driveshaft isn't being powered by the engine, and having unlocked hubs in 4Hi-Normal mode would burn up the viscous coupler in your NP219 transfer case (a $350 item, when you find one).
It will have the D44 front axle and the AMC20 rear axle with one-piece axles and bigger tubes than the weaker units used on CJ's. Gearing will be either 2.73's or 3.31's.
It has an AMC 360ci V-8, which is completely different from the Dodge 360ci V-8 (though they do share the same specs for lifters, so those interchange). But no, you'd have to go with another '72-'91 AMC V-8, which includes 304's, 360's and 401's.
Bob Barry-
* '78 Cherokee 4-door "S"
* '88 Grand Wagoneer
* '84 XJ Cherokee 2-door FOR SALE- $600
All that and more on the page below:
<a href="http://home.off-road.com/~wagoneer/" target="_blank">http://home.off-road.com/~wagoneer/</a>
Bob Barry is offline   Reply With Quote
Unread 03-14-2012, 07:12 PM   #3
jeepfreek80
hmm..?
is it possible to change the transer case and front diff from an 82 with free wheeling hubs into a 1980 constant 4x4
jeepfreek80 is offline   Reply With Quote
Unread 03-18-2012, 12:51 AM   #4
carnuck
1984 J-Series Truck
yes. If you go to a NP208 you will need a longer rear shaft
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
http://tinyurl.com/jimsclads
'82 Honcho Sportside project 360 4 speed NP208 $1500
'81 Eagle wagon with upgrades $2800
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3000
carnuck is offline   Reply With Quote
