1979 SJ I got for free - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > 1979 SJ I got for free
Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-16-2010, 10:11 PM   #16
warrior99
Originally Posted by BrianBFD View Post
Thanks for posting the pics
You're welcome. It was a little harder because I'm on my iPod touch lol
warrior99 is offline   Reply With Quote
Unread 03-17-2010, 10:18 AM   #17
BrianBFD
Here, hold my beer...
BrianBFD's Avatar
I'll get the first 3 digits of the VIN and post them this evening. I was saying 79 because of an tag receipt I found in it said it was a 79.
Originally Posted by No-Doors View Post
...I will be tied up the 13th and 14th...
Originally Posted by AKABOB View Post
I am aroused.
BrianBFD is offline   Reply With Quote
Unread 03-17-2010, 05:45 PM   #18
1976j10
1976 J-Series Truck
It looks like it's in pretty good shape. Take good care of it.
1976j10 is offline   Reply With Quote
Unread 03-18-2010, 04:04 PM   #19
greenbeater
1968 FSJ Wagoneer
looks like my junk just 2 dr. and mine has an older dash. (cuz it is a 68)
good lookin rig, enjoy..
clicky lefty for specs and here for cardomain
http://www.cardomain.com/ride/2212742/1
greenbeater is offline   Reply With Quote
Unread 03-18-2010, 06:42 PM   #20
BrianBFD
BrianBFD's Avatar
Originally Posted by BJ's Off-Road View Post
Not bad...
By the way, it is a 1978 or earlier. It has the earlier grille and bumper, which would explain the 401.
What is the VIN number (or the first 3 digits) and I'll tell you exactly what year it is.
The first 3 digits appear to J8A
It' a little hard to tell, the sticker thing in the door jamb is pretty chewed up.
I am aroused.
Unread 03-18-2010, 06:46 PM   #21
Mickey_D
There will also be a stamped plate on the dash directly behind the windshield on the driver's side (at least there should be...).
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
Mickey_D is online now   Reply With Quote
Unread 03-18-2010, 06:51 PM   #22
JeepGuyBrian
Looks like you got yourself a new fish-truck! (I can say that because I see you are from upper Midwest so you'll understand.... )
JeepGuyBrian is offline   Reply With Quote
Unread 03-18-2010, 06:54 PM   #23
JeepGuyBrian
You can actually decode it yourself if you'd like, kind of interesting to learn the vehicle history. Courtesy of Edmunds.com:
World Manufacturer Identifier
The first three digits make up the World Manufacturer Identifier (WMI)
  • Position one represents the nation of origin, or the final point of assembly. For instance, cars made in the U.S. start with 1,4 or 5, Canada is 2, Mexico is 3, Japan is J, Korea is K, England is S, and Germany is W.
  • Position two tells you about the manufacturer. For example, A is for Audi, B is for BMW, L is for Lincoln and N is for Nissan.
  • Position three indicates the vehicle's type or manufacturing division. For example, 1G1 represents Chevrolet passenger cars; 1G2, Pontiac passenger cars; and 1GC, Chevrolet trucks.
Vehicle Descriptor Section
Digits 4 through 9 make up the Vehicle Descriptor Section (VDS).
  • Positions four through eight tell you about the car, such as the model, body type, restraint system, transmission type, and engine code.
  • Position nine, the "check" digit, is used to detect invalid VINs based on a mathematical formula that was developed by the Department of Transportation.
Vehicle Identifier Section
Digits 10 through 17 make up the Vehicle Identifier Section (VIS).
  • Position 10 indicates the model year. The letters from B-X correspond to the model years starting with 1981, with X bringing up the rear with 2000; model years 2001 and up are indicated with numbers, starting with the number 1. There is no I, O, Q, U or Z. Confusing? Here's a list of the model years: B=81, C=82, D=83, E=84, F=85, G=86, H=87, J=88, K=89, L=90, M=91, N=92, P=93, R=94, S=95, T=96, V=97, W=98, X=99, Y=00, 1=01, 2=02, 3=03, 4=04, 5=05, 6=06, 7=07, 8=08, 9=09, A=2010.
  • The letter or number in position 11 indicates the manufacturing plant in which the vehicle was assembled. Each automaker has its own set of plant codes.
  • The last 6 digits (positions 12 through 17) are the production sequence numbers. This is the number given to your car on the assembly line.
Unread 03-18-2010, 09:48 PM   #24
BJ's Off-Road
1979 FSJ Cherokee
Just ignore his advice, it would only be good for 1981 and up vehicles... unless of course you think your Jeep was made in Japan...
BJ's Off-Road is offline   Reply With Quote
Unread 03-18-2010, 09:57 PM   #25
BJ's Off-Road
1979 FSJ Cherokee
Now, I will help decode your vin properly....
J - Jeep Corp
8 - 1978
A - 1972-1979 Left Hand Drive Built in Toledo (not Japan...)
The rest I'll guess at:
17 - 2-door Cherokee Chief 109" Wheelbase
N - 6200# GVW
Z - 401 V8 4bbl
The rest should be the serial number. So your vin should be J8A17NZ XXXXXXX
Unread 03-20-2010, 04:09 PM   #26
DIX03TJ
looks like you got some serious mold growing on your door panels and seats. Get some simple green and a rag and clean that up. good to see another FSJ being worked on
DIX03TJ is offline   Reply With Quote
Unread 03-20-2010, 09:05 PM   #27
BrianBFD
BrianBFD's Avatar
Actually I'm from and still live in coastal Alabama.
J - Jeep Corp
8 - 1978
N - 6200# GVW
Z - 401 V8 4bbl
Spot on, exactly.
Yeah, it needs lot of love at this point, as I said before it was abandoned in the middle of a field and left.
Can anyone tell me what I need to do to go about replacing the carb?
I am aroused.
Unread 03-23-2010, 07:17 PM   #28
802Hoop
1981 J-Series Truck
Awesome Jeep! Right price too.
You could always rebuild the existing carb, probably cheaper. As far as pulling and replacing, I'll let the subject matter experts answer. I would venture to guess that my 258 carb is a little different .
802Hoop is offline   Reply With Quote
Unread 03-23-2010, 07:21 PM   #29
BrianBFD
BrianBFD's Avatar
One problem with the rebuild idea. There's not one to rebuild.
I am aroused.
Unread 03-23-2010, 07:24 PM   #30
802Hoop
1981 J-Series Truck
Yeah, I suppose you are right... lol, I must have missed that part.
