1978 Jeep Cherokee - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > 1978 Jeep Cherokee
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deliJeep XJ Cherokee Ulitmate Sliders now available!
Unread 02-28-2007, 08:17 PM   #1
PriceP64
1978 Jeep Cherokee
I just recently purchased a 78 Jeep Cherokee for $800 and I want to replace the stock front and rear bumpers with custom 32 Front and Rear Tube Bumpers. The problem is all the bumpers that I have found are for a 79-91 Jeep Cherokee and I was wondering if they are still able to adapt to a 78 body style. My goal in this Jeep is to use it for off-roading and climbing. I have already purchased a BJ's 2 inch Lift Springs with U-bolts and a Steering Stabilizer Shock - Stock Replacement Pro Comp Stabilizer Shock for a lift kit, I bought Pro Comp Series 51 Steel Wheels 15x8 Pro Comp Series 51 Steel Wheels - 3.5-inch backspacing with Pro-Comp Radial All Terrain Tires 31x12.50R15 Pro-Comp All Terrain Tires and also have the Jeep getting painted next week. If there is anything else that you think I would need for the Jeep for what I want to do with it, it would be greatly appreciated if you let me know
PriceP64 is offline   Reply With Quote
Unread 03-02-2007, 01:00 AM   #2
carnuck
1984 J-Series Truck
I'm not sure what year they changed the front frame and bumper mounts, but I think you can retro fit the newer ones. I can't on my '73 because the bumper mount would hit my front spring mounts. ('73 was the last year of spring over front stock)
carnuck is offline   Reply With Quote
Unread 03-02-2007, 07:46 AM   #3
J4GRAND
79 was the year they went to the newer bumper style but like Carnuck said, your 78 can be modified. I believe that you have to add some extensions to the front frame ends that were present on the 79s but not 78s and earlier. I don't think the rear bumper changed all that much.
Patrick V.
Valparaiso, IN
73 Jeep J4000 360 .040 over, Summit K8600 Cam, Edelbrock Manifold and 750CFM 4V TH400/1339 QT
78 Cherokee Chief- Hunting Property Rig
05 Grand Cherokee- 3.7 V6 5 speed auto
J4GRAND is offline   Reply With Quote
Unread 03-03-2007, 08:54 AM   #4
carnuck
1984 J-Series Truck
I take it you saw the Killer32 bumpers on my Jtruck? (in the show your rig section)
