-   Full Size Jeep Forum (http://www.jeepforum.com/forum/f57/)
-   -   1974 wagoneer (http://www.jeepforum.com/forum/f57/1974-wagoneer-1416041/)
cordell2016 09-11-2012 12:08 PM
first jeep ever and i need help!1974 wagoneer
I'm 16 and I was given a 1974 wagoneer about a month ago and i'm more of a ford guy and i know alot about cars and trucks body and mechanical but a jeep is a little out of my zone.... all i know about it is the year and that it is all stock... I want to restore it on the cheap, but i have no idea were to start at and what to get.... I want to put a 3 or 4 inch lift kit on it and put some 30 or 33 inch tires on it. the body is in not the best shape but it can be fixed, there is rust is on the rockers and flood pans on the back fenders.... ok the body is border like ****. If anyone has any suggestions for any improvements or replacement parts please reply..... and if anyone knows of a bigger engine that would fit in it....
73pumpkin 09-17-2012 08:23 PM
I,ve got a 73 wag I'm working on. You can put a 401 in them if you can find one. Check your floor boards for rust. A guy called Dr. Marns has a 73 build thread that is very good.
cordell2016 09-18-2012 06:17 AM
the drivers side floor is rusted to sh*t, but the passengers side has just a little rust hole... I have heard that the 401 would fit but i was not 100% sure if it was... Thanks for the reply
CSP 09-18-2012 07:50 AM
All of the AMC V8s are dimensionally the same on the outside. It's the bore and stroke that differ. I know where there's a 401 for sale too that came out of a '76 Cherokee (see signature);)
cordell2016 09-18-2012 08:45 AM
ya, i have been reading up and i found one a little ways away from me..... thanks
BJ's Off-Road 09-18-2012 08:50 AM
We have lots of replacement parts for these:
http://www.bjsoffroad.com/
Floor panels, rocker panels and quarter panels:
http://www.bjsoffroad.com/ProdList.asp?scat=12
Thanks!
cordell2016 09-18-2012 09:58 AM
thanks that helps a-lot... i have been looking for panels for a long time...
cordell2016 09-19-2012 08:49 AM
would any of you guys know how to take the dash off, i was trying to take it of to clean up and cant get off the top part... any help would be a big hlep....
BJ's Off-Road 09-19-2012 09:25 AM
There are some bolts for the dash pad that are underneath the windshield so you need to take the windshield out to remove it.
cordell2016 09-22-2012 05:37 PM
here is my next problem, the tailgate was stuck shut and after a-lot of WD-40 and time i got it open, but now it will not latch. I have taken a look in side the tailgate but can't see anything wrong. Any advice?
pleontks 09-23-2012 10:03 AM
i have to slide mine to one side or the other
cordell2016 09-25-2012 08:48 AM
well nether of the latches latch
olliehopnoodle 09-25-2012 03:21 PM
It depends on what your intended goal is. It seems obvious you are not going for a 'factory concurs restoration', which is a good thing if you are on a budget. ;)
Are you going to daily drive it? Weekend fun cruizer? Mild trail rig?
Lots of things that can be done, these are great rigs to 'make your own'.
Bj's offroad is a good place to start to see what types of things are available. They probably have the 'most complete' selection in one place and their web site is pretty easy to use.
The engine is probably a 360 or possibly a 401.
If it's an automatic, the transmission is a TH400. Great 3 speed tranny.
Automatic will have a quadratrac transfer case. Good case but certain parts are no longer available.
It should have d44 axles front/rear. Good axles with plenty of parts available.
Overall a good combo for a fun weekend car or trail rig. As a daily driver if you have to go long distances the gas might eat up your wallet.
So you should be able to just freshen up the drive train. Tuneup/fluid change and not spend too much money.
That means you can put a little cash into a spring lift. Your springs are probably pretty tired anyways. Some decent shocks and bigger tires. That will make it a fun driver and decent trail rig.
cordell2016 10-10-2012 05:58 AM
Alright guys i have another question if anyone can answer it... the ignition locks in any car but it is a son-of-a to get it unlocked... I don't have the money now to buy a new one or and the junk yard don't have one.... (P.S. got her fired up and out for a drive the other day... sounds good and don't leak anything.. Thanks for all the Help!
73pumpkin 10-11-2012 12:02 PM
I'd blast a little WD40 in the thing or some PB blaster. It is amazing that you don't have a lot of fluid leaks. Check the levels on things to make sure they are not bone dry. Glad to hear you've got it running.
The time now is 11:21 PM.
