ZJ_flexxxer's manche build - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > MJ Comanche Technical Forum > ZJ_flexxxer's manche build
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 09-01-2012, 12:21 AM   #76
newfieZJ
No , never maxed it out because I know , but I can't abuse it or disconnect either till it's fixed .
Yeah , I thought I read before those had a different thread
Thanks for the link , will check it out
newfieZJ is offline   Reply With Quote Quick reply to this message
Unread 09-27-2012, 02:06 PM   #77
ZJ_flexxxer
1994 ZJ
been meaning to post this pic but haven't got around to it. here's the comanche pulling what's left of the donor xj into the scrapyard. 3300lbs not including the weight of the trailer! i love this little truck
MY OTHER TOOLBOX IS A JEEP
94 ZJ Laredo--lifted 4.5", rocker rails, front end/t-case/gas tank skids, tube doors, wj knuckle/brake swap, soft 8's, 32x10.50 tsl's [URL="http://www.jeepforum.com/forum/f197/project-la-re-do-rebuild-thread-1212129/"][COLOR="Blue"]BUILD THREAD[/COLOR][/URL]
87 MJ Comanche--zj d44 rear w/ disc brakes, wj knuckles/brakes w/ drilled & slotted rotors,6" lift in progress [URL="http://www.jeepforum.com/forum/f53/zj_flexxxers-manche-build-1349142/"][COLOR="Blue"]BUILD THREAD[/COLOR][/URL]
90 XJ Laredo--D.D., satin black paint job, 15" ecco's, the redheaded step child of my jeeps
87 XJ Wagoneer--R.I.P. =(
[URL="http://www.youtube.com/user/DirtHicksVideos"][COLOR="Red"][FONT="Showcard Gothic"][U][SIZE="5"]SUBSCRIBE TO MY YOUTUBE CHANNEL![/SIZE][/U][/FONT][/COLOR][/URL]
ZJ_flexxxer is offline   Reply With Quote Quick reply to this message
Unread 12-30-2012, 08:56 PM   #78
ZJ_flexxxer
1994 ZJ
well i got bored today and decided to fab up a dual steering stabilizer. i've always thought this truck could use one after the lift it felt unstable on bumps in the road. so started out with two peices of angle iron, i basically just laid them opposite of each other and held the stabilizer end between them to get the right width and then tacked them together.
then i ran a bead down each side
then i cut it down to size
after that i did a little grinding and smoothing and then welded it into place in front of the coil spring plate almost identical to the opposite side and at a slight outward angle to reach the tie rod
then i made some tabs to mount the stabilizer to the tie rod and welded those on
and here's how it came out
then a fresh coat of paint!
Unread 01-18-2013, 04:43 PM   #79
redbeard144
1994 ZJ
just read your build got great ides for my zj.thanks .... i lifted my zj with jy springs and parts i cut my track bar and made it longer works fine for me. i used small angle iron on top and bottom of the weld for support . that way you dont have to re-cut your tie end bar. do you like the wj up grade,and was it worth the trouble?
redbeard144 is offline   Reply With Quote Quick reply to this message
Unread 01-18-2013, 05:01 PM   #80
ZJ_flexxxer
1994 ZJ
i upgraded my zj with the wj brakes first and loved it, so i couldn't have anything less on my daily driver. i love the stopping power of the dual piston calipers, i'd recommend it to anyone who drives their jeep on the street a lot.
