ZJ_flexxxer's manche build - Page 2 - JeepForum.com
post #16 of 80 Old 07-29-2012, 09:40 PM Thread Starter
ZJ_flexxxer
1994 ZJ
made some progress today. i finished grinding on the axle and got the new spring perches welded on.
not the pertiest welds but the feed was acting up on my welder a bit today and i'm not the most skilled welder anyway. i gave them the BFH test and they passed.
then i went and bought some new u-bolts and i reversed the sides the u-bolt plates were on so that i could still use the existing shock mounts on them.
dana 44 in, but still need a drive shaft, shocks, and brake lines
and then i get to start on the front lol. so here's the out come of my spring over axle lift
MY OTHER TOOLBOX IS A JEEP
94 ZJ Laredo--lifted 4.5", rocker rails, front end/t-case/gas tank skids, tube doors, wj knuckle/brake swap, soft 8's, 32x10.50 tsl's
87 MJ Comanche--zj d44 rear w/ disc brakes, wj knuckles/brakes w/ drilled & slotted rotors,6" lift in progress
90 XJ Laredo--D.D., satin black paint job, 15" ecco's, the redheaded step child of my jeeps
87 XJ Wagoneer--R.I.P. =(
ZJ_flexxxer is offline
post #17 of 80 Old 08-03-2012, 03:35 PM Thread Starter
ZJ_flexxxer
1994 ZJ
33's?
and i just ordered a set of these
post #18 of 80 Old 08-05-2012, 08:17 AM Thread Starter
ZJ_flexxxer
1994 ZJ
well i went to the jy yesterday for a bit. found a lifted xj and a lifted zj there. I stole these rear shocks from the zj. not sure what brand they are but they're some pretty nice shocks and they have the nice big rubber bump stops at the top which i like. got them home and touched up the silver paint a bit.
and then from the lifted xj i stole this adjustable tracking arm and the bracket. the best part is, i got all of these parts for only $22 bucks . although i might have got a little wet from a short storm that decided to pass through while i was there i think it was well worth it.
post #19 of 80 Old 08-05-2012, 10:28 AM Thread Starter
ZJ_flexxxer
1994 ZJ
well i got my new shocks on this morning. I knew it was probably gonna take some fabricating, and it did but not much at all. I just relocated the shock mounts to the axle and used the existing upper mounts. it worked out pretty good, after i got it off jackstands and on the ground i still have about 6" of upward travel and i'm not even sure how much down travel(A LOT i'll just put it that way lol).
i couldn't help myself so i got in the bed and jumped around and i do believe she's gonna ride quite nice. can't wait to finish everything up and drive it.
post #20 of 80 Old 08-05-2012, 10:24 PM Thread Starter
ZJ_flexxxer
1994 ZJ
bought some 33's already mounted on cragar soft 8's today. been trying to get these things from a guy on craigslist since thursday. finally got them, and for only $200
got 2 of them on the back already, just getting an idea of how it'll look.
post #21 of 80 Old 08-06-2012, 12:51 AM
parkerkcfan
Lookin' good
parkerkcfan is offline
post #22 of 80 Old 08-06-2012, 03:19 PM Thread Starter
ZJ_flexxxer
1994 ZJ
well if you all remember this picture below is what brought me into this crazy rear end swap/lift. after getting the rear end in and the lift done on the back. i finally decided it's time to make this thing pull itself again.
you can't see it so well in the pic, but the ears on the yoke were ground down so much that it wasn't able to hold in a c-clip anymore. but with a little determination, my welder, and a dremel tool, i managed to repair it. i welded a bead around the grounded spots on the yoke an built it back up to where it should be. then used a dremel to grind them back into shape somewhat and clean out the holes where the u-joints would be going in. then finally used the dremel again with a small cutting wheel to cut out the grooves that the c-clip sits in.
i know this may not seem like much to some ppl, but i'm only 23 years old and just now starting to get alot of fabrication under my belt. and i have to say, i'm very proud of myself on this one. most ppl would have taken it to a shop, or thrown it out and went to the junkyard for another one, or had a new one built at a shop. but i was bound and determined to make it work and i did.
and here she is after her test drive. this thing rode smoother than it ever has since i've owned it. i'm very happy with how it's went so far, i just hope i can still say the same after i lift the front.
post #23 of 80 Old 08-10-2012, 06:21 PM Thread Starter
ZJ_flexxxer
1994 ZJ
well i got my parts in today. 4-6" rough country shocks for the front, got one of them as a scratch and dent for only $12.00. not sure what was wrong with it, can't find anything so far.
and i got my adjustable control arms from a guy on ebay. very impressed with these things. i wasn't expecting to unwrap something so BEEFY! love these things, i might even sell the full set i have for my zj and buy a set of these.
once i got done having a mini christmas morning on the tailgate of my truck, i got to work. anybody wanna buy a 2wd dummy axle??
post #24 of 80 Old 08-10-2012, 09:49 PM
njjeep12
good build so far
njjeep12 is offline
post #25 of 80 Old 08-11-2012, 07:51 AM Thread Starter
ZJ_flexxxer
1994 ZJ
Originally Posted by njjeep12 View Post
good build so far
thanks
post #26 of 80 Old 08-12-2012, 06:31 PM Thread Starter
ZJ_flexxxer
1994 ZJ
went to the JY today and got a d30 with 3:73's to match the new d44 in the rear.
didn't get much done after that. was kinda feelin lazy today. i took what was left of the upper control arms off and knocked the old bushings out of the mounts.
i also took the brakes off, since i'm gonna go back to the JY next weekend and get some WJ knuckle's and brakes for the bigger brake swap.
post #27 of 80 Old 08-14-2012, 10:18 PM Thread Starter
ZJ_flexxxer
1994 ZJ
nice little update for today...
so i noticed today, one of the lower control arm mounts somehow got bent either at the JY or in the process of getting it home. so i'll have to get that fixed.
got some more old parts removed including the knuckles and axles/hubs.(not very good pics, i worked late tonight)
i also picked up some new cv axles
so today i came up with a little plan to make my sway bar links disconnect if i want. i used a speed bit to make my bolt holes a little larger
and i picked up some 3 point tractor pins from TSC. worked out pretty nice i think
post #28 of 80 Old 08-19-2012, 06:19 PM Thread Starter
ZJ_flexxxer
1994 ZJ
made it to the JY today and got a set of wj knuckles and calipers. didn't have any luck finding a set of the '02-up akebono calipers but oh well, still better than the stock single piston's.
and i also ordered some drilled/slotted wj rotors and ceramic pads
that's it for now. waiting on money for more parts lol
post #29 of 80 Old 08-19-2012, 08:43 PM
jakesjeepmj1988
1988 MJ Comanche
I need to do that to mine to stopping power is not that awesome on those thing with stock brake set up
jakesjeepmj1988 is offline
post #30 of 80 Old 08-19-2012, 09:43 PM Thread Starter
ZJ_flexxxer
1994 ZJ
mine was horrible, which was part of my decision in switching to the d44 rear w/ disc brakes.
i did the wj knuckle/brake swap on my zj and it made a HUGE difference in stopping power and i even used the JY rotors and pads because they still had some life left in them. I'm yet to put new rotors/pads on there so i can't wait to see what this thing is gonna stop like with rear disc's and wj dual pistons with drilled/slotted rotors and ceramic pads. should stop on a dime lol
Looking to buy a manche! What do you think about this one? RedneckJacob MJ Comanche Technical Forum 8 02-05-2012 05:34 PM
looking at a manche Bain98xj MJ Comanche Technical Forum 5 01-24-2011 10:38 AM
looking for a yellow manche build eflores MJ Comanche Technical Forum 1 03-03-2010 09:47 AM
91 Manche Rwork MJ Comanche Technical Forum 6 12-16-2006 01:18 PM
New '88 manche! SoloCamo MJ Comanche Technical Forum 7 10-31-2006 01:05 PM
